Problem with more member in a structure
Hi there,
I'm using STM32F103 with Keil ver 4.72
I defined a structure like this:
typedef struct
 uint16_t X;
 uint16_t Y;
 uint16_t Width;
 uint16_t Height;
 uint16_t BackColor;
 uint16_t TextColor;
 uint16_t TextBackColor;
} button_t;
I use the struct in main file like this:
button_t btn1;
int main()
 btn1.X = 100;
 btn1.Y = 100;
 while(1)
When I use this struct in program, every things works well.
The problem is when I add more members into the structure, like this:
typedef struct
 uint16_t X;
 uint16_t Y;
 uint16_t Width;
 uint16_t Height;
 uint16_t BackColor;
 uint16_t TextColor;
 uint16_t TLX;
 uint16_t TLY;
 uint16_t TRX;
 uint16_t TRY;
 uint16_t BLX;
 uint16_t BLY;
 uint16_t BRX;
 uint16_t BRY;
When I do that, program compiles without any problem, but when I download it into the MCU, it doesn't work.
I increased Heap Size from 0x0200 to 0x0800, but took the same result. I set the Heap Size in startup.s file. I'm not sure if it's a right way to set that.
  • Tells us nothing.
    We have no idea how your code is using this structure.
    Presumably, you've also added code to do stuff with the extra members - maybe that's where the problem lies, rather than the structure itself?
    So what debugging have you done to find out where it's going wrong?
    "I increased Heap Size"
    Why do you think it's a heap size problem?
    How To Debug: www.avrfreaks.net/.../2418156
  • Thank you,
    How can I attach the project here?
    I defined the struct in main.c
    **      http://www.kavirElectronic.ir & www.kavirelectronic.ir/eshop
    **      support Team:
    **      http://www.IranMicro.ir  & http://www.IranMicro.ir/forum
    **       kavirelectronic.com@gmail.com
    **      0352-7730313  0352-7734146
    #include "usart.h"
    #include "lcd.h"
    #include <stdio.h>
    #include <string.h>
    #include "stm32f10x.h"
    #include "font.h"
    //#include "button.h"
    typedef struct
            uint16_t LocationX;
            uint16_t LocationY;
            uint16_t SizeWidth;
            uint16_t SizeHeight;
            uint16_t BackColor;
            uint16_t TextColor;
    //      uint16_t PosTLX;
    //      uint16_t PosTLY;
    //      uint16_t PosTRX;
    //      uint16_t PosTRY;
    //      uint16_t PosBLX;
    //      uint16_t PosBLY;
    //      uint16_t PosBRX;
    //      uint16_t PosBRY;
            char *Text;
    } button_t;
    button_t Button1;
    int main()
            //char str[9];
            u16 x,y;
            //u8 bufff[]="!!!abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz";
    u8 bufff[] = "!!!abcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyzabcdefghijklmnopqrstuvwxyz";
            Usart_Configuration(115200);
            printf("Â´Â®ØŸØ¹Â³ÙØªÂ¼Â»Â¯Â³Ø©Â¹Â¦\r\n");
            Button1.LocationX = 300;
            Button1.LocationY = 300;
            Button1.SizeHeight = 100;
            Button1.SizeWidth = 200;
            Button1.BackColor = 0x0503;
            Button1.TextColor = 0x0000;
            Button1.TextBackColor = 0x0000;
            //Button1.Text = "Aghil";
            //ButtonSetText(&Button1, "Key1");
            //strcpy(Button1.Text, "Key 1");
    //      Button1.Text[0] = 'A';
    //      Button1.Text[1] = 'g';
    //      Button1.Text[2] = 'h';
    //      Button1.Text[3] = 'H';
    //      Button1.Text[4] = NULL;
            LCD_Init();
            LCD_Clear(0xfff8); //0xf800 //0x0f0000
            //LCD_Highlight(0xff0000);
            x=y=0;
            //LCD_DisplayString2(0,0,bufff,0,0xffff);
            //LCD_DisplayString2(100,100,Button1.Text,0,0xffff);
    //      for (i=0; i<0xFFFF; i+=100)
    //              sprintf(str,"%05u", i);
    //              LCD_DisplayString(0,0,str,0xffff,0x0);
    //              LCD_DisplayString(0,32,bufff,i,i);
            //LCD_DisplayString2(200,200,"Aghil",0xffff,0x0);
            //LCD_PutChar2(200, 200, 'A', 0xffff, 0x0);
            //_DrawRect(200, 200, 300, 300, 0);
            //LCD_FillArea(201, 201, 299, 299, 0x1818);
    //      Button1.FontHeight = acFont32_GetHeight();
    //      Button1.FontWidthMin = acFont32_GetMinWidth();
    //      Button1.FontWidthMax = acFont32_GetMaxWidth();
            //ButtonShow(&Button1);
            while(1);
    //      while(1){
    //              while(!(USART1->SR&USART_FLAG_RXNE));
    //              if(x >799)                     /* ¼ى²éت£سà ؟ص¼نتا·ٌ×م¹»         */
    //                  x = 0;
    //              y = y + 16;                        /* ¸ؤ±ندشت¾×ّ±ê                 */
    //              if(y > 479)                       /* ×Ù×ّ±ê³¬³٠                  */
    //                          y = 0;
    //              LCD_PutChar(x,y,USART1->DR,0,0xffff);
    //              x += 8;
    As you can see in the code, I just assigned some value to some of structure members, and I don't use it in other places. When I Uncommecnt variables shown in structure, program doesn't run on MCU. Also I can't debug in that case. When I stop debug mode, an error occurs and tells about JTAG cable. When I Comment those varibles, program run properly and I can debug properly, too.
    I can send you project files, just tell me how to share them.
  • Hello,
    char *Text;
    allocates enough memory for a POINTER, not for the string.
    If you do
    and I assume the pointer is 32bit, access to [0].[3] might not do what you want, but also does not corrupt the memory. But Button1.Text[4] would destroy some memory.
    do
    typedef struct
            uint16_t LocationX;
            uint16_t LocationY;
            uint16_t SizeWidth;
            uint16_t BackColor;
            uint16_t TextColor;
    //      uint16_t PosTLX;
    //      uint16_t PosTLY;
    //      uint16_t PosTRX;
    //      uint16_t PosTRY;
    //      uint16_t PosBLX;
    //      uint16_t PosBLY;
    //      uint16_t PosBRX;
    //      uint16_t PosBRY;
            char Text[20]; // max. required number of charactern required in app
    } button_t;
    instead
  • Thank you G. Bohlen,
    You are right but i think it isn't my problem. That part of code you mentioned is comment as below, and I didn't use Textarray anywhere.
    Also if I declare an array with length of for example 20, program does not run on MCU because of the problem that is the issue of this topic.
  • You've probably muffed up your memory allocation.
    Sensible debugging should point you in the right direction.
    You fo know how to debug don't you?
  • You keep saying that, but it is plainly not true!
    Of course the code runs - but, when it runs, it crashes!
    Your job in debugging is to first find where it crashes; and then work out why it crashes.
    "That part of code you mentioned is comment"
    So don't post code that's full of irrelevant junk!
    Clean it up before posting - you may well find your own error in the process!
  • Fair enough, but do you understand why that code is bad?
    Are you sure that you haven't made a similar mistake - or mistakes - elsewhere ... ?
  • Thank you,
    The example uses TFT LCD via FSMC interface in the project. When I debug program by JLINK, while writing data to FSMC bus (address 0x60020000), debugger crashes (shows an error about JTAG cable). I really don't know why. I just used another example and there wasn't this problem in it. I uploaded the example here
    www.filedropper.com/28stm32showchartft7inch
    Program compiles successfully, but crashes on hardware.
  • As I said before:
    With all you've written since I could change that to::
    You've almost definitely muffed up your memory allocation.
    Check it!
