USBD_HID_GetReportTrigger problem: works only once
I am writing USB HID Device driver for ARM M0+ and got a problem with sending data from device to host. The device can send data only on the first call of USBD_HID_GetReportTrigger(). The all others calls of USBD_HID_GetReportTrigger() does nothing, it does not call back ARM_USBD_EndpointTransfer(). If I directly call ARM_USBD_EndpointTransfer(0x81, &but, 1) from main() then device can send data to host as many times as requested, no problem. I can see in memory two bits of difference in MDK usbd_config_0.o module (one is in usbd0_data->endpoint_active[17] and another looks like in usbd_driver_semaphore_cb_mem). If clear those two bits in MDK memory after USBD_HID_GetReportTrigger() got stuck then USBD_HID_GetReportTrigger() can call ARM_USBD_EndpointTransfer() again.
  • Hi Val,
    can you describe your environment a bit better:
    - MDK version?
    - Middleware version?
    - microcontroller board/chip?
    Best regards, Milorad
  • Hi Milorad,
    Here are details:
    MDK-ARM Plus Version:5.23
    MDK-Middleware 7.4.0
    Board: SVT31W74
    Microcontroller: S1C31W74
    USB driver full speed.
    Today I made a hack in ARM_USBD_EndpointTransfer() that makes USBD_HID_GetReportTrigger() working again.
    #include "rl_usbd_lib.h"
    extern usbd_data_t usbd0_data;
    int32_t ARM_USBD_EndpointTransfer(uint8_t ep_addr, uint8_t *data, uint32_t num) {
    usbd0_data.endpoint_active[17] = 0;
    return ARM_DRIVER_OK;
    I do not think this is an appropriate solution and am looking for a real fix.
    Regards,
    Val
  • Hi Val,
    which driver are you using for the USB?
    Which chip have you selected in MDK?
  • Hi Val,
    sorry I saw now that you are actually writing an USB Device driver yourself, excellent.
    Well, what your driver is probably missing is that it needs to call a callback SignalEndpointEvent from the IRQ when endpoint transfer has finished (or failed). And that callback is provided to driver as a parameter to USBD_Initialize function when it is called from middle layer.
  • Hi Milorad,
    I think you talking about ARM_USBD_EVENT_IN and I have a call of SignalEndpointEvent(num, ARM_USBD_EVENT_IN) in IRQ routine and it gets called. I even tried another delayed extra call of it but it did NOT help. And it did not clear usbd0_data.endpoint_active[17].
    Milorad, any idea what could be wrong?
    Can I have the source code of USB core?
    Regards,
    Val
  • Hi Val,
    I actually have a good idea what could be wrong.
    For IN endpoints you have to call SignalEndpointEvent with first parameter ORed with 0x80.
    Meaning for Endpoint 1 IN, you should call SignalEndpointEvent(0x81, ARM_USBD_EVENT_IN).
