A51 Problem Error #4 line 1 without details
hello,
it is my first step with AT89C2051 try to assemble this program
with A51 assemble ..
and at 1srt comile i get 5 erros,
i corrected one, wich what clearly indicated in the *.lst result.
But they are 3 remainings errors
Error 4 Line 1
Nothing suspect (by me !) inside the *.lst result .
So , i request an advice from specialist ..
what could be thoses errors ?
; date 30.01.2018
; correction error ligne 233
; removedall comments (because size over 7000cars)
   ORG 0000H
JMP START
    ORG 0003H
RETI
     ORG 000BH
LJMP INTT0
     ORG 0013H
RETI
     ORG 001BH
LJMP INTT1
     ORG 0023H
RETI
;  Main procedure
START:
   MOV R0,#70H ;
   MOV R7,#0BH ;
CLEARDISP: MOV @R0,#00H ;
INC R0 ;
DJNZ R7,CLEARDISP ;
MOV 20H,#00H
MOV 7AH,#0AH
MOV TMOD,#11H
MOV TL0,#0B0H
MOV TH0,#3CH
MOV TL1,#0B0H
MOV TH1,#3CH
SETB EA
SETB ET0
SETB TR0
MOV R4,#14H ;
START1: LCALL DISPLAY ;
JNB P3.7,SETMM1 ;
SJMP START1 ;
SETMM1: LJMP SETMM ;
;  Timing procedure of one second
INTT0: PUSH ACC
PUSH PSW
CLR ET0
CLR TR0
MOV A,#0B7H
ADD A,TL0
MOV TL0,A
MOV A,#3CH
ADDC A,TH0 ;
MOV TH0,A
SETB TR0
DJNZ R4, OUTT0
ADDSS:
MOV R4,#14H
MOV R0,#71H
ACALL ADD1 ;
MOV A,R3
CLR C
CJNE A,#60H,ADDMM ;
ADDMM: JC OUTT0
ACALL CLR0
MOV R0,#77H
ACALL ADD1
MOV A,R3
CLR C
CJNE A,#60H,ADDHH ;
ADDHH: JC OUTT0
ACALL CLR0
MOV R0,#79H
ACALL ADD1
MOV A,R3
CLR C ;
CJNE A,#24H,HOUR ;
HOUR: JC OUTT0
ACALL CLR0
OUTT0: MOV 72H,76H
MOV 73H,77H
MOV 74H,78H
MOV 75H,79H
POP PSW
POP ACC
SETB ET0
RETI
;      Flicker the procedure while adjusting-
INTT1: PUSH ACC
PUSH PSW ;
MOV TL1, #0B0H
MOV TH1, #3CH ;
DJNZ R2,INTT1OUT
MOV R2,#06H
CPL 02H
JB 02H,FLASH1
MOV 72H,76H
MOV 73H,77H
MOV 74H,78H
MOV 75H,79H
INTT1OUT: POP PSW
POP ACC ;
RETI ;
FLASH1:
JB 01H,FLASH2
MOV 72H,7AH
MOV 73H,7AH
MOV 74H,78H
MOV 75H,79H
AJMP INTT1OUT
FLASH2: MOV 72H,76H
MOV 73H,77H
MOV 74H,7AH
MOV 75H,7AH ;
AJMP INTT1OUT
;  Add a sub procedure
ADD1:
MOV A,@R0
DEC R0
SWAP A
ORL A,@R0
ADD A,#01H
DA A ;
MOV R3,A
ANL A,#0FH
MOV @R0,A
MOV A,R3
INC R0
SWAP A
ANL A,#0FH
MOV @R0,A
RET
;  Zero clearing procedure
CLR0:
CLR A ;
MOV @R0,A
DEC R0
MOV @R0,A
RET
;   The clock adjusts the procedure
SETMM:
cLR ET0
CLR TR0
LCALL DL1S
JB P3.7,CLOSEDIS
MOV R2,#06H
SETB ET1
SETB TR1
SET2: JNB P3.7,SET1
SETB 00H
SET4: JB P3.7,SET3
LCALL DL05S
JNB P3.7,SETHH
MOV R0,#77H
LCALL ADD1
MOV A,R3
CLR C
CJNE A,#60H,HHH
HHH: JC SET4
LCALL CLR0
CLR C
AJMP SET4
CLOSEDIS: SETB ET0
SETB TR0
CLOSE: JB P3.7,CLOSE
LCALL DISPLAY
JB P3.7,CLOSE
WAITH: JNB P3.7,WAITH
LJMP START1
SETHH: CLR 00H
SETHH1: JNB P3.7,SET5
SETB 01H
SET6: JB P3.7,SET7
LCALL DL05S
JNB P3.7,SETOUT
MOV R0,#79H
LCALL ADD1 ;
MOV A,R3 ;
CLR C ;
CJNE A,#24H,HOUU
HOUU: JC SET6
LCALL CLR0
AJMP SET6
SETOUT: JNB P3.7,SETOUT1
LCALL DISPLAY
JNB P3.7,SETOUT
CLR 01H
CLR 00H
CLR 02H
CLR TR1 ;
CLR ET1
SETB TR0
SETB ET0
LJMP START1
SET1: LCALL DISPLAY
AJMP SET2
SET3: LCALL DISPLAY
AJMP SET4
SET5: LCALL DISPLAY
AJMP SETHH1
SET7: LCALL DISPLAY
AJMP SET6
SETOUT1: LCALL DISPLAY
AJMP SETOUT
;   Reveal the procedure
DISPLAY: MOV R1,#70H ;
MOV R5,#0FEH
PLAY: MOV A,R5
MOV P3,A
MOV A,@R1
MOV DPTR,#TAB
; MOVC A,@ADPTR ; Check that reveals the data correspond to one section of codes   <--  5 ERRORs
; ERROR A4
; A51: ERROR 4 (BAD INDIRECT REGISTER IDENTIFIER)
;This indicates that the register or register combination is not valid for indirect access.
; For example, @R7, @R3, @PC+A, @DPTR+A. <- ????
MOVC A,@A+DPTR  ; Check that reveals the data correspond to one section of codes   <--- 3 errors
MOV P1,A ;
LCALL DL1MS
INC R1 ;
MOV A,R5
JNB ACC.5,ENDOUT
RL A ;
MOV R5,A
AJMP PLAY ;
ENDOUT:
 SETB P3.5
MOV P1,#0FFH
RET
TAB: DB 0C0H,0F9H,0A4H,0B0H,99H,92H,82H,0F8H,80H,90H,0FFH
; One section of code tables of male genital altogether
; †0″ †1″ †2″ †3″ †4″ †5″ †6″ †7″ †8″ †9″ †Non- bright â€
;  Time delay procedure
DL1MS:
MOV R6,#14H
DL1: MOV R7,#19H
DL2: DJNZ R7,DL2
DJNZ R6,DL1
RET
DS20MS: ACALL DISPLAY
ACALL DISPLAY
ACALL DISPLAY
RET
DL1S: LCALL DL05S
LCALL DL05S
RET
DL05S: MOV R3,#20H
DL05S1: LCALL DISPLAY
DJNZ R3,DL05S1
RET
END
message on MDOS windows ( i used DOSBOX 0.74 to use AR1.EXE) inside WIN10
MS-DOS Macro assembler A51 V4.4
Object module palced in clock.obj
Assembler invoked by : A51 clock.asm
ASSEMBLER COMPLETE 3 ERRORS Found
nota: i can't join the *.lst , because more > 7000 cars
is it possible to joint a file (clock.lst) ?
  • ; removedall comments (because size over 7000cars)
    what Mickey-Mouse stuff are you using giving you that limit?
  • IS that actually the Keil assembler?
    "size over 7000cars"
    Is that a limit of this forum, or of the assembler?
  • yes, it is a forum limitation, for max number of char inside the message
    my *.lst file is over 12K (with adresses and comments)
    is it possible to join a *.txt file or *.zip file ?
    i did not see about this possibility as on other forum.
  • is it possible to join a *.txt file or *.zip file ?
    I suspect you mean 'attach'.
    Not on this forum. But anyway, I don;t think there are many professionals here who would give the time to just freely look at a 12K+ list file. Better to just give the relevant portion.
    I certainly wouldn't bother to open up a file of that size without being paid.
  • asm portion
       ORG 0000H
    JMP START
        ORG 0003H
    RETI
         ORG 000BH
    LJMP INTT0
         ORG 0013H
    RETI
         ORG 001BH
    LJMP INTT1
         ORG 0023H
    RETI
    ;  Main procedure
     .. etc ....
    and after compile ..
    A51 MACRO ASSEMBLER      CLOCK                                                               DATE  30/01/18   PAGE     1
    MS-DOS MACRO ASSEMBLER A51 V4.4
    OBJECT MODULE PLACED IN CLOCK.OBJ
    ASSEMBLER INVOKED BY:  A51 CLOCK.ASM
    LOC  OBJ            LINE     SOURCE
                           1     ;
    *** _________________________^
    *** __________________________^
    *** ___________________________^
    *** ERROR #4, LINE #1, BAD (OR MISUSED SPECIAL) CHARACTER
                           2     ;
                           3     ;
    0000                   4        ORG 0000H
    0000 020024            5     JMP START
                           6
    0003                   7         ORG 0003H
    0003 32                8     RETI
    000B                   9          ORG 000BH
    000B 020055           10     LJMP INTT0
    0013                  11          ORG 0013H
    0013 32               12     RETI
    001B                  13          ORG 001BH
    001B 0200A9           14     LJMP INTT1
    0023                  15          ORG 0023H
    0023 32               16     RETI
                          17
                          18     ;  Main procedure
    i can't see what is the error in the line #1 ?
  • Your first line is:
    did you copy/paste it here correctly?
    If you did, then you need to realise that the assembler will try to interpret that line. For it to be a comment it must start with a semi colon.
    If in doubt, just delete the whole of line 1. It's only there to make the code look pretty, and it fails badly with that task anyway!
  • Again, is this actually the Keil assembler?
    Here is an example of Keil's A51 listing: http://www.keil.com/support/man/docs/a51/a51_xc.htm
    Note that it does not say anything about MS-DOS ...
    "i can't see what is the error in the line #1 ?"
    Look again:
    What needs to be the first character on a comment line ... ?
  • hello,
    Tanhk's for answer
    but i add manual this ************ to separate the texte,
    before using the specific tag
    in reality this line doesn't existe in my asm file
    else i know, it needs to add ";" for comment
  • Then the question is what have you actually got as the first line of your file?
    Has it an unusual file encoding? Can you open the file with a hex editor and view the hex value of each character in the file?
    Some encoding schemes (such as unicode) prefix a file with the encoding details that might be interpreted by an editor or viewer but confuse the hell out of an assembler.
  • i can't see what is the error in the line #1 ?
    Seriously? I mean come on man, how much more brutally can the tool point you at exactly the things it objects to, short of sending an actual person who beats you over the head with them?
                           1     ;
    What you're looking at there is one of those supposedly clever ideas that are actually completely bone-headed: a byte order mark in an UTF-8 encoded text file, where it's not needed at all. Turn that off in your text editor, and never think of this nonsense again.
    And for Pete's sake, consider using a version of the tools that isn't older than yourself!
  • Thank's P.Summer for your valuable answer .
    I changed the encoding to Ansi instead of UTF8 ..
    and compile is now OK , without errors.
    Some Geeks on this forum could better think twice before to speak
    and respect the Old person.
