LPC11U68 ADC read value oscillates
does anybody have an example code of using ADC of NXP LPC11U68? I have a very oscillating output even if I use battery supply or add additional capacitor. The filter capacitors on VREFP and VREPN are used as defined in Product datasheet. Besides how do I enable sequence B? If I try the same procedure as by sequence A nothing is converted. My code is below.
#define SETBIT(X, Y) (X |= 1 << Y)
#define CLEARBIT(X, Y) (X &= ~(1 << Y))
int main(void)
{ // Variables char cText[20]; unsigned long ulVal;
// System init targetInit();
// LCD init LCD_Init();
// SETTING OF ADC, channel 1 // Function 1 - ADC, channel 1 PIO0_23 = 1;
// Analog mode for pi CLEARBIT(PIO0_23,7);
// Enable CLK for ADC SYSAHBCLKCTRL |= 1 << 13;
// Enabling power for ADC, bit 4 to 0 CLEARBIT(PDRUNCFG,4);
// Autocalibration AD_Self_calibration();
// The conversion clock is equal to system clock AD_CTRL &= ~(0x000000ff);
// In sequence A set to sample channel 1 SETBIT(AD_SEQA_CTRL,1);
// Enable sequence A SETBIT(AD_SEQA_CTRL,31);
// First line of LCD LCD_Write_string(" AD value ");
// Cursor to second line LCD_Set_position(2,1);
// Second line of LCD LCD_Write_string(" U = 0000 mV ");
while(1) { // Start of conversion AD_SEQA_CTRL |= (1<<26);
// Waiting to finish conversion while(CHECKBIT(AD_DAT1,31)==0);
// Reading DAT register ulVal = AD_DAT1;
// Extrude the proper value ulVal = (ulVal >> 4);
// Extrude the proper value ulVal = ulVal & 0x0FFF;
// Calculation ADC value in mV ulVal = 1000*VREF*ulVal/4095;
// Cursor to second line LCD_Set_position(2,8);
// Formet the display sprintf(cText, "%4d", ulVal);
// Write ADC value to LCD LCD_Write_string(&cText[0]);
// Pavza pause(); }
Thank you for helping!
Jure
  • Please recheck your post. Your source code is very confusing, all commented out?
    And please read this:
    http://www.keil.com/forum/tips.asp
    before you post something new.
  • SystemCoreClockUpdate()
    void ADCInit( uint32_t ADC_Clk )
      /* Disable Power down bit to the ADC block. */
      LPC_SYSCON->PDRUNCFG &= ~(0x1<<4);
      /* Enable AHB clock to the ADC. */
      LPC_SYSCON->SYSAHBCLKCTRL |= (1<<13);
      LPC_IOCON->PIO0_23   &= ~0x9F; /* Clear bit7, change to analog mode. */
      LPC_IOCON->PIO0_23   |= 0x01;  /* ADC IN7 */
      LPC_ADC->CR = ( 0x01 << 0 ) |  /* SEL=1,select channel 0~7 on ADC0 */
            ( ( SystemCoreClock / ADC_Clk - 1 ) << 8 ) |  /* CLKDIV = Fpclk / 1000000 - 1 */
            ( 0 << 16 ) |             /* BURST = 0, no BURST, software controlled */
            ( 0 << 17 ) |             /* CLKS = 0, 11 clocks/10 bits */
            ( 0 << 24 ) |             /* START = 0 A/D conversion stops */
            ( 0 << 27 );              /* EDGE = 0 (CAP/MAT singal falling,trigger A/D conversion) */
      return;
  • I believe that, most LPC11Uxx example codes on the Internet are for LPC11U1x/2x.
    The LPC11U3x has a 10-bit ADC with a maximum 10-bit conversion rate of 400 kSamples/s.
    For LPC11U3x ADC, the analog voltage supply and ADC reference voltage shared with VDD.
    The LPC11U6x has a 12-bit ADC with a maximum 12-bit conversion rate of 2 MSamples/s (VDD = 2.7 V to 3.6 V)
    or 1 MSamples/s (VDD = 2.4 V to 2.7 V). The LPC11U6x ADC uses dedicated pins for Analog voltage supply (VDDA) and ADC reference voltage (VREFP, VREFN).
    The A/D converter includes a built-in, hardware self-calibration mode. In order to achieve the specified ADC accuracy, the A/D converter must be recalibrated, at a minimum, following every chip reset before initiating normal ADC operation.
  • Hello,
    thank you for response. I am also very sorry to miss out the source code format. Am publishing the code again. In an example that you have published I can see that the code is not for LPC11U68, because all ADC settings are made in CR and SEQA and SEQB are missing. Thank you for and further suggestions.
    int main(void)
    // Variables
    char cText[20];
    // System init
    targetInit();
    // LCD init
    LCD_Init();
    PIO0_23 = 1;
    // Analog mode for pin PIO0_23
    // Autocalibration
    while(1) {
            ulVal = AD_DAT1;
            // Format the display string
            // Write ADC value to the LCD
            // Pause
            pause();
  • 16.3.1 Perform a single ADC conversion using a software trigger
    To perform a single ADC conversion for ADC0 channel 1 using the analog signal on pin
    ADC_1, follow these steps:
    1. Enable the analog function ADC_1.
    2. Configure the system clock to be 50 MHz and select a CLKDIV value of 0 for a sampling rate of 2 Msamples/s using the ADC CTRL register.
    3. Select ADC channel 1 to perform the conversion by setting the CHANNELS bits to 0x2 in the SEQA_CTL register.
    4. Set the TRIGPOL bit to 1 and the SEQA_ENA bit to 1 in the SEQA_CTRL register.
    5. Set the START bit to 1 in the SEQA_CTRL register.
    6. Read the RESULT bits in the DAT1 register for the conversion result.
    TRIGPOL = bit 18
    SEQA_ENA = bit 31
    START = bit 26
  • TRIGPOL
    Select the polarity of the selected input trigger for this conversion sequence.
    Remark: In order to avoid generating a spurious trigger, it is recommended
    writing to this field only when the SEQA_ENA bit (bit 31) is low. It is safe to
    change this field and set bit 31 in the same write.
  • Hi,
    thank you for an advice. Setting TRIGPOL bit to 1 really helped. I was reading the manual, but it was not clear to me why this bit should be used if we have software trigger. Ok, I will use this bit in a future. But I need to mention that also the result of the AD conversion is better in mean of oscillating if I have disconeted the debugger. Of course this happened by mistake :)
    Thank you again for all advices!
    Regards,
    Jure
