Hi All,
I have lpc1768 evaluation board and i am trying to test i2c0/1 on Keil before actual testing on board.
I am able to send START bit and I am able to see START transmission completed event. After this when I write slave address (0x50), I am getting NACK event in status register.
Is it possible to test i2c on keil ? If yes how do I select slave ?
Please let me know.
Best regards, Rayagonda
What are you expecting here?
I2C is a communication link - it requires interactions between both the master and the slave.
Keil provides a simulation of the microcontroller - but not the other end of the link.
Maybe you could look at using debug functions:
http://www.keil.com/support/man/docs/uv4/uv4_debug_functions.htm
But, to be honest, I really doubt it's worth it.
With readily-available, cheap dev boards and on-chip debug, why bother with simulation? Far easier to just do it in real life!
Or, if you must, look at something like Proteus: www.labcenter.com/.../
Double check the slave address, some implementations you might need to shift the address bits as they appear as the top 7 bits in the byte transmitted over the wire.
If none of the addressing works, the device could simply not be functioning.
Look at the signals with a scope, and compare the bit positions with those in the data sheet for the slave part.
This type of work requires attention to detail, which means reading and understanding the documentation for the parts involved and how they interact.
