Hey guys, I'm currently working on the network application in C and ARM.
I'm trying to continuously pass UDP strings from my PC to a new box. It works perfectly. However, I am getting seemingly random faults after a couple of minutes of usage. Any help would be apprenticed!
Instrument your code, sanity check your pointers, and allocations. Understand your stack usage and program flow.
I will send you the code. Plz check for me.
what is ur email?
Really not looking to work on your assignment, and likely don't have the hardware with which to effectively test/exercise it.
Like I said get it to a place where you can actually observe enough detail to pin down the issue, and clean up the code so the obvious points of failure can be identified and flagged. Have a proper Hard Fault handler so you can focus in on the problem areas.
