Hi all, I have a MCB11C14 from Keil (MCB1000, Cortex M0) and I try to use I2C peripheral. As there is no CMSIS driver for such board, I was looking for an official library, but nothing seems to exist. I have tried a library proposed by RSL : github.com/.../lpc11xx.keil-examples-CMSIS-update but nothing happens on the I2C Bus. I am surprised that nothing is proposed for such usual peripheral with this board. Does someone know how to play with it (without register access if possible)? Best regards, Xavier
The peripheral is the domain of the chip manufacturer - it's not affected by the board.
I suggest that you look to the chip manufacturer (NXP) for peripheral drivers
www.nxp.com/.../iar-lpc11c14-evaluation-board:OM13003?tab=Design_Tools_Tab
www.nxp.com/.../keil-lpc11c14-evaluation-board:OM13004?tab=Design_Tools_Tab
Thank you for your answer. I am working with Keil uVision, that's why I was not looking at LPCOpen. I will try to take a look at the link you proposed. Best regards, Xavier
LPCOpen is just a set of libraries - it is not locked to any particular IDE.
The included examples cover Keil, IAR, and LPCXpresso
www.nxp.com/.../lpcopen-libraries-and-examples:LPC-OPEN-LIBRARIES
Thank you, it helps a lot ! Best regards,
