Hello ..
I am having a very weird issue with my code piece .. The MCU is STM32F407VET6 .. What I'm trying to do is sending a string via USART1 peripheral module .. In order check if the character in the USART1 is sent out of the USART1->DR register I am continuously checking the "Transmit Complete Bit of the usart1 status register The code below works well ...
#define TC1 *((uint32_t *)(0x42220018)) //Previously defined at //the top of the main file void EXTI4_IRQHandler(void) { uint8_t i; char x[6]="BURAK\n"; EXTI_PR_Bit4=1; // Cleared by writing 1 // ISR code TC1=0; for(i=0;i<7;i++) { USART1->DR=x[i]; while(!(USART1->SR&USART_SR_TC));// Transmit Complete ? } TC1=0; }
BUT !
When I replace
with
while(TC==0);
The code stucks.. freezes ... and stops ...Why does it happen ?? Are Bit-Band Aliases not reliable things to use with while ,if , for statements ?? Does it have to be read/modify/write sequence always ??
Thanks in advance ..
Look up the volatile keyword.
Not sure.
Try these changes -
#define TC1 *((__IO uint32_t *)(0x42220018)) //#define TC1 *((uint32_t *)(0x42220018))
and
while (TC1 == 0); // while (TC==0);
Sorry Kevin - you posted first.
Just take my post as a second vote for volatile, affirming your suggestion.
As not a great idea to send out the USART like this in a IRQ_Handler.
Thanks Robert. Always nice to have the support of someone who really knows their subject :)
Thanks it solved with volatile keyword ... Is there a diffence between __IO and volatile keywords ??
__IO is not a keyword - it is just a #define
Look at the #define ...
all peripheral registers are defined as volatile. That's where the difference actually is.
community.st.com/.../45696-while-loop-stucks
