When using USER commands is it possible to detect whether it is a 'build' vs. a 'rebuild'. Should there be a key-sequence to do so, but in the docs I found no info ?
I would like to let the USER-command know to do a clean build.
Refer to: http://www.keil.com/support/man/docs/uv4/uv4_commandline.htm and see the options: -r (rebuild) -b (build)
Thanks for the reply, but I am looking not to call uv4.exe, but to have an indication in the Project/USER/Before Build custom commands about the the build type.
This is not possible, I am sorry
