I want to log some physical data using debugger. I have added the variables where the values are loaded into a watch window. The values change continuously. Is there a possibility that i log the data into a file , with time stamp. I did some basic check on the web, looks there are two commands LOG and SAVE, but i understand none of them help in this regard. Thanks a lot in advance for any support on this topic.
If it is possible, then it's probably going to involve the use of uVision Debug Functions:
www.keil.com/.../uv4cl_debug_functions.htm
But wouldn't it be a whole lot simpler to just have the microcontroller send the data to a serial port, and capture that at the PC?
TeraTerm can even add the timestamps for you
https://ttssh2.osdn.jp/
There are plenty of alternatives for capturing data from a PC serial port ...
