Dear all,
We are programming a 8051 core in C and we are experiencing crashes which are related to interrupts.
The machine in question uses 2 DACs to control servo motors. These motors rotate 2 C-shaped hands which needs to be homed. This homing (moving to default position) is done by 4 interrupts, 2 for each hand. Each hand has a sensor to detect the opening.
First we let the hands turn and we use a software counter to let them speed up, once at speed I enable 2 external interrupts which are triggered on the opening sensors.
The external interrupts make sure that the hands are steered in the opposite direction at full force to let them stop quicker.
Both external interrupts also start 2 hardware timers at a 1ms interval. These timer interrupts are used to track the time of the counter pulse and to turn the motors off.
Occasionally this action results in complete system reboot. It can go well a 100 times or it may reset after the 5th homing action. The crashs always occurs after the homing, this is why we are convinced it must be related to the interrupts.
The code which starts the motors and enables the external interrupts:
case lowerNippleHands: // lower nipple arms and store the spokes if mininum torque isn't reached nippleKeysOnNipples=0; // control a pneumatic cylinder rimMotorEnabled = 0; // controls a relais leftServoSCREW = 0; // these are the 4 dacs used to controll the servo motors rightServoSCREW = 0; leftServoUNSCREW=zeroLoadTorqueLeft+10; rightServoUNSCREW=zeroLoadTorqueRight+10; // start both motors in unscrew direction at low torque gotoCase(lowerNippleHands+1,150); // 300ms delay to the next case break; case lowerNippleHands+1: updateTorque_bool = false; leftServoUNSCREW=255; // turn the motors at full power rightServoUNSCREW=255; leftServoSCREW=0; rightServoSCREW=0; gotoCase(lowerNippleHands+2,100); // 200ms delay to next case break; case lowerNippleHands+2: iex2=0; // ensures the ISR does not gets executed when ex2 is set, iex3=0; // " " same for #3 ex2=1; // start listening to upgoing flank of nipple home sensor (enables the ISR) ex3=1; // these interrupts set two timer interrupts which give a pulse to stop the nipple keys. if(menu == TESTMACHINESEQUENCE) updateTorque_bool = true; readySignal = true; break;
The interrupt code is as follows:
void ISR_ex2(void) interrupt ex2_vector // left nipple hand home sensor { ex2=0; leftServoSCREW=255; // initialize counter pulse leftServoUNSCREW=0; counterL = 0; // clear this counter TR1 = 0; // start timer 1 TH1 = ((-500 >> 8) & 0xff); TL1 = (-500 & 0xff); TR1 = 1; ET1 = 1; } void ISR_ex3(void) interrupt ex3_vector // right nipple hand home sensor { ex3=0; rightServoSCREW=255; // initialize counter pulse rightServoUNSCREW=0; counterR = 0; // clear this counter TR2 = 0; // start timer 2 TH2 = ((-100 >> 8) & 0xff); TL2 = (-100 & 0xff); TR2 = 1; ET2 = 1; } void ISR_timer1(void) interrupt timer1_vector // timer 1 to stop left nipple key 1 ms interval { counterL++; if(counterL==counterPulseL) { ET1 = 0; TR1 = 0; leftServoSCREW=0; leftServoUNSCREW=0;} else { TR1 = 0; // restart timer 1 TH1 = ((-500 >> 8) & 0xff); TL1 = (-500 & 0xff); TR1 = 1;} } void ISR_timer2(void) interrupt timer2_vector // timer 2 to stop right nipple key 1 ms interval { counterR++; if(counterR==counterPulseR) { ET2 = 0; TR2 = 0; rightServoSCREW=0; rightServoUNSCREW=0;} else { TR2 = 0; // restart timer 2 TH2 = ((-100 >> 8) & 0xff); TL2 = (-100 & 0xff); TR2 = 1; } }
Our leading theory is the crash/system reboot is perhaps a memory overlap between an ISR call and a function call with arguements.
I was wondering if any of you could shed some light on this matter. Could the 'using' keyword resolve our issue? Than we would let the interrupts using an alternative register bank.
I am open for ideas and suggestions.
Bas
Methinks you have stack overflow. try adding to all
void ISR...(void) interrupt vector using 1
If you use interrupt priorities the 'using' must be different for high and low
also moving some rarely used veriables to xdata may be needed
stack overflow is easily checked bu filling stack pointer to end of idata with 0xff running with a breakpoint in reset and checking the memory when it breaks
We fixed most crashes but there are still a few remaining. They have also became extremely rare compared to what we have. We broke many records in crash free operations. The crash involving the 2 external interrupts and the 2 timer interrupts seem to be gone permanently.
The crashes that remain, happen during 2 functions which are called from timer0.
The primary timer related function use timer0. Timer0's ISR icrements 1 counter, it makes a function call to a function which also increments 2 counters and it checks 2 if statements. If these if statements are true, function calls are executed.
There is one function which takes an ADC sample and calculates an average, the other function is used for a PID function to turn a bicycle wheel. Both functions are written to be executed quickly
All functions linked to timer0 now use register bank 1. I know that doing this for the ISR is critical but I am less sure about the other functions. That remains a little bit mumbo jumbo for us. But as it couldn't hurt I thought it was a good idea to type using 1 behind all these functions.
There is also a spoke sensor which counts the spokes and make some calculations. This sensor is linked to external interrupt 0 which has a lower priority. For this ISR we use register bank 3.
So far we have had 2 times, that the machine showed odd behaviour during the rotation of the wheel (an I/O toggled about 6 times during 1~1.5 seconds). And the spoke counter lost track of a spoke.
During rotation, the spoke ISR is obviously active as well as timer0's PID function.
I believe that the timer ISR which has the highest priority may disrupt things. I also believe that the function calls may bring undesirable behaviour.
This very same machine has already been programmed in a slightly primitive assembly language which dates back to a linker which allowed a max of 6 character variables. So we looked into this code and learned that the same timer critical stuff uses timer2 instead of timer0. Timer2 has a lower priorty than all other used interrupts.
Currently we are swapping timer2 and timer0's functions in an attempt to solve more possible crashes. Our timer functions are not extremely critical and they can and should have a lower priority than all others.
Furthermore I want to reduce the functions to preferebly 0 calls so we do less redundant stuff. And prevent potential stack overflows.
The crashes that remain, happen during 2 functions which are called from timer0. principally do not ever call functions from ISR's if you absolutely have to (do do not) then make sure they have the same 'using' also calling functions add to stack usage
