I am stumbled on use of the --multifile option of armcc. I need it to build a large application image that would not fit the chip otherwise (a few hundreds of bytes gained from optimizations matter)
Instead of build from Keil, I made a batch script (based on generated by the IDE) with a single-pass compilation of all sources.
The problem is that for final linking I get no the result of the compilation.
In the simplest form, with just two files the build script is like this:
armcc -c -c99 --cpu Cortex-M0 --li -g -O3 --apcs=interwork --split_sections ^ -I ..\ARM\CMSIS\Include ^ -I ..\nrf51822\Include ^ -I Common ^ -I Main ^ --gnu --bss_threshold=0 ^ -D__MICROLIB ^ -D__UVISION_VERSION=525 ^ --info=totals ^ --list ^ --multifile ^ --omf_browse .\app_multifile.crf ^ Main\main.c ^ Startup\system_nrf51.c ^ -o "./multi_app.o"
if either main.c or system_nrf51.c is left, then the compilation produces the output file. 2+ source files give no such result.
I can see that other files are generated (.crf, .lst) and all sources are really built - it takes long time for my 30+ sources and warnings/errors are reported (if introduced to the source). I'd expect the result appearing in the current directory, and it cannot be found anywhere.
What am I missing?
BR, Oleksandr
