Hi, I have an issue concerning a dll, not recognized when I use the debug session. Here is the recap of the issue : I use the version 5.21a (and cannot upgrade my version, work restriction)and will mostly use the debug session. In the option for target -> Debug ,I checked the "Use simulator". I tried to re-built the project, verify the path (via tools.ini) and also re-install the software ! I paste the file Mydll.dll in the directory of ARM/BIN/ (the dll was tested on an another PC and is working! ),add the parameter : "-dMydll" (next to -pCM0 )in the Dialog DLL parameter. When I launch the start-stop Debug session I have the warning : "The specified DLL was not found C:\\unsupported\Keil_v5\BIN\ARM\Mydll Continuing without specified peripheral "
I double checked the path and the name of the dll and I can't understand why Keil cannot find the dll.
Thank you by advance for you answer !
Mat
PS :I use Keil uvision
"I paste the file Mydll.dll in the directory of ARM/BIN/ "
Sorry : 'The specified DLL was not found C:\\unsupported\Keil_v5\ARM\BIN\Mydll Continuing without specified peripheral
