PC tool for ADUC7026 flash memory program on factory path
I look for a PC application to program ADuC7026 micro controller's flash on factory path, using JTAG.
I use uVision 4 for compile/debug/flash program for ADuC7026. But for factory path is not so good application. So I look for small simple application to flash only ADuC7026, without any other functionalities. Such application should use a USB-JTAG adapter and HEX file for flash program
  • Your factory should have the capability to do this - talk to them!
    It would normally be done as part of the manufacturing process - usually part of final test.
    An alternative is to have the chips programmed before placing on the board - talk to your supplier, or search for 3rd-party programming services.
    Ask the chip manufacturer.
    This is really nothing to do with Keil.
  • Andrew,
    Thanks for quick answer.
    We are small start up. Factory that we think to use does not have any experience with ADuC70xx line. So we should supply to the factory tools for such programming.
    "An alternative is to have the chips programmed before placing on the board - talk to your supplier, or search for 3rd-party programming services."
    Each our board will equipped with JTAG connection and we plan to program ADuC7026's flash in factory steps. I posted this question here after speaking with our AD supplier in our country.
    Let me to conclude our conversation.
    Keil has no any separate/stand alone PC tool for ADuC7026's flash program. I'm right? Best regards, Yakov
