Hi everybody, I have a problem with my STM32Cube Framework (API). I have Keil 5.0 and STM32F0xx_DFP 2.0.0. I installed STM32CubeMX(v5.0.0) software but when I try to start STM32F0CubeMX from Keil RTE, I get the error " *** Error: STM32CubeMX could not be found ! CubeMXLauncher termiates with error code 3 " from STM32CubeMXLauncher.exe file.
I installed STM32CubeMX software to its default folder.
Is there anyone who has an idea about the solution of this problem?
So does it work if you try to start it from outside Keil?
Yes. There is no problem when I start it directly from its folder.
Check if the STM32CubeMxLauncher.exe is present in the pack folder, so for ex.: \Keil_v5\ARM\Pack\Keil\STM32F4xx_DFP\2.13\MDK\CubeMX\
If not, then I would suggest to either update to latest DFP version and in case it is already updated, then delete the pack and install it again.
CubeMX Launcher exe file exists in Keil_v5\ARM\Pack\Keil\STM32F0xx_DFP\2.00\MDK\CubeMX\ directory. When I click the start button in Keil RTE or run CubeMXLauncher.exe file directly, I get that error. I tried reinstalling DFP, Keil MDK, CubeMX(v5.0.0 and v4.27) seperately. I even tried changing OS language to English (for the possibility that Launcher.exe can't find the CubeMX because of any special character somewhere) even if I don't have any special character in directories. I think I need to add CubeMX to "installed programs" list of my PC. But I don't know how to do this.
Thanks for your suggestions.
Have you managed to resolve this issue? I am having it too.
https://community.st.com/s/question/0D50X0000AYpoqPSQR/keil-stm32cubemxlauncherexe-couldnt-find-stm32cubemx
You can find my solution for this problem from the link attached.
