Trace no synchronization
Hi guys,
I'm facing a very weird behavior from my program and I do not find any answer to my problem.
I have a program, which runs on a STM32F3 board. Everything used to work fine, I was able to access the debugger directly and debug it.
A couple of days ago I needed to try a new module so I used one of the example provided by ST in the directory of stmcube . I compiled my program, used the debug menu and everything went well.
Now I am trying to use my old program again, but I am not able to connect to my board with the debuger. Every time I try, I get : Trace: No Synchronization.
I went to my project's settings,double checked the core clock frequency(72MHz). I also verified the Xtal(12MHz).
But still nothing works. I'm not by any means able to debug my board with my old program( which I used to be able).
Does anyone have an idea about my problem?
Thank you very much !
Amine
