CPU usage hits 100% when trying to debug
When I start debugging, the CPU usage hits 100% and Keil gets stuck. Only 1 out of 50 times I am able to start debug.
The only setting that is selected is the "load application on startup".. If I uncheck it the debug starts, but when I try to load the application via command "Load incremental" keil gets stuck again.
