Hey guys i am trying to implement USB hostlite with fat32. I read your all messages and implemented those changes in my code but i did not get success yet. www.siwawi.arubi.uni-kl.de/.../lpc17xx_chanfat_mthomas_20100715c_pub.zip
This site is not showing any output. Please help me out how to solve this problem. How to write diskio.c file.
Hello Ankush,
There are CMSIS-PACK examples for the Keil MCB1700 Evaluation board
Open the Pack installer, C:\Keil_v5\uv4\PackInstaller.exe
- On the top left of the window, for "Search", type "LPC1768" - the list below gets filtered. - Select the device (entry with a green icon) from the list below – on the right side of the dialog updates with Software Packs relevant to this device - For "Packs", install the Keil:LPC1700_DFP pack (if necessary) - On the top right of the screen, select the yellow "Examples" tab. - On the "USB Host Mass Storage (MCB1700)" row, click the "copy" button - a dialog pops up. - Pick a directory, click both the check boxes, and press OK - a new Keil µVision session opens with the example. - Build the project, Connect a USB cable to the board and start the debugger
See also - the Getting Started guide at http://www.keil.com/gsg - Learning page http://www.keil.com/learn - Creating applications at http://www.keil.com/support/man/docs/uv4/uv4_ca_packinstaller.htm
