Dear community,
I used a Lite version of keil uVision5 for my STM32L0 boards.
Right now, I would like to use the IDE with my new evaluation board Apollo2 AMAPH1KK-KBR EVB from Ambiq micro.
I've download the Ambiq Micro Apollo Series Device Support from the Pack Installer(written Up to date after Apollo_DFP) and unpacked it. However, when I want to select the device from the Device Database, I'm only seeing the STM32L0 available. So, when I want to compile a project example, the build output is following :
Error: *** Project 'clkout', Target 'clkout', Device 'Ambiq Micro::AMAPH1KK-KBR' is not supported by Toolchain ! ***
What should I do to forced the IDE to choose the device in device database since the Series Device Support is already installed? Can I use the Toolchain to program my board with a Lite version ?
Best regards.
>>Can I use the Toolchain to program my board with a Lite version ? Probably, but not if you installed an STM32 CM0 license key.
What version of uV5 specifically, current is like 5.26
