FRDM-KL25Z project link error Undefined symbol Driver_I2C0
I created a project for my FRDM-KL25Z board.
In "Manage Run-Time Environment", I added I2C using CMSIS Driver | I2C | Multi-Slave.
My app code includes "Driver_I2C.h".
My code compiles, but I get a linker error:
Error: L6218E: Undefined symbol Driver_I2C0 (referred from i2c_multislave.o).
See details below.
I guess Driver_I2C0 is declared in a library that is missing from my project.
Can somebody point me to some uVision docs that would help me correct the problem?
Thanks,
Bruce Graham
IDE-Version:
µVision V5.24.2.0
Copyright (C) 2017 ARM Ltd and ARM Germany GmbH. All rights reserved.
License Information:
Bruce Graham
TechnoSoft Engineering
Flex license: MDK-ARM Essential: 1 user(s) (mdk_essential)
Operation stops: 30 Sep 2019
Tool Version Numbers:
Toolchain: MDK-ARM Essential: 1 user(s) Version: 5.24.1
Toolchain Path: e:\Keil_v5\ARM\ARMCC\Bin
C Compiler: Armcc.exe V5.06 update 5 (build 528)
Assembler: Armasm.exe V5.06 update 5 (build 528)
Linker/Locator: ArmLink.exe V5.06 update 5 (build 528)
Library Manager: ArmAr.exe V5.06 update 5 (build 528)
Hex Converter: FromElf.exe V5.06 update 5 (build 528)
CPU DLL: SARMCM3.DLL V5.24.1
Dialog DLL: DARMCM1.DLL V1.18.0.0
Target DLL: UL2CM3.DLL V1.160.3.0
Dialog DLL: TARMCM1.DLL V1.13.0.0
  • I know how to add I2C support in other IDE projects. I just don't know how to do this in Keil.
    Since I added I2C to my project using the "Manage Run-Time Environment" dialog, I am assuming that this would have added the required I2C library to my project.
    Since the error indicates that the linker is looking for an object named "Driver_I2C0", I am guessing that a library, or some Keil provided source code, needs to be added to my project.
    What additional steps do I need to do to add I2C to my project?
    Thanks,
    Bruce
    Thanks,
    Bruce
