when trying to connect the U-Link pro debug/trace unit from µVision with the board the debugger is recognized but the Target Driver Setup shows an SWD error in the SW Device Field.
The board in use is the S32K148EVB from NXP ( www.nxp.com/.../s32k148-evaluation-board:S32K148EVB ) The functionality of the U-Link pro debugger and the connections was verified on a STM32 and is working as expected.
The µVision version is 5.25.2.0 with a valid license (MDK-ARM Essential / Pro both tested) As project, the example project "Blinky" which is available for the S32K148 from the pack installer was used. All available packs for the processor are installed and updated.
The project can be built and flashed via alternative debuggers and interfaces.
Most other options like U-Link drivers, project/target/debug settings and board configs have been tested and checked multiple times.
The question would be if the Setup between the S32K148 and the U-Link pro has been proven to work and if yes, you could provide an example project with a step by step guide for the setup.
Thanks in advance -Michael
