After solving a series of errors communicating with the LPC824M201JHI33 the error invalid Rom table started occuring, even though the board responds to code sent before the first occurrence of said error and none of the solutions we found worked. please help.
How are you observing that?
Everytime I try to download to flash the error shows up, I'm using the CMSIS-DAP debugger and I´ve tried changing the debug settings to no avail.
Which particular CMSIS-DAP debugger are you using?
LPC-LINK2 CMSIS-DAP V5.182
Hi Nuno,
can you put the microcontroller into an ISP mode by boot pins, and try then?
Best regards, Milorad
