I Wanted to use STM32H743BI Controller in my project.In the software and tool information for this board(STM32H743BI ) they have mentioned that keil version 5 is supported for the evaluation board(STM32H743BI ), but in the device data base of keil version(5.26) STM32H743BI board is not there. also i checked in IDE'S programming algorithm there is no internal flash for my board(STM32H743BI ). Do anyone have any idea about the same.
Build or clone one of the template project from the ST HAL examples they place in the CubeMX repository. Built and downloaded thing for the EVAL and NUCLEO boards here.
Hello sir!!
I'm not getting what you wanted to say..can you please explain in details as i'm new to STM32H series.my question is I wanted to use STM32H743BI Controller in my project, and wanted to use keil5.0 ide because i’m familiar with keil but my device stm32h743 is not in device database of keil5.0 version.
Here is a script to guide you..
Download and unpack www.st.com/.../stm32cubeh7.html
Open the template project, or one of the hundred other projects STM32Cube_FW_H7_V1.2.0\Projects\STM32H743ZI-Nucleo\Templates\MDK-ARM\Project.uvprojx
Keil uV5 should download the appropriate Packs, and be able to build this. It should also be able to download and debug via the ST-LINK debugger.
You should also be able to cut-n-paste the "Template" to another directory at the same level, and give it a different name, and add and remove, or copy in, the code you want.
You can review the layout, form and construction of the project.
For push button service a troupe of monkeys can create code for you via CubeMX. www.st.com/.../stm32cubemx.html
Current version of Keil uV is 5.25, if that's not what you're using download a current version www.keil.com/.../arm.htm
uV 5.22 seems sufficiently capable
