Hellow every one, am using keil MDK 5.25 to develope a c++ code with c++11 features which is not supported at keil how can i enable c++11 features MDK 5.25 if it can be done
thanks,
Do the GNU/GCC compiler support the features you want? If so, select that MDK uses those.
www.keil.com/.../armclang_ref_eap1505750157591.htm
