Hello, I realized a few weeks ago a code that works on a nucleo card with the following RF module X-NUCLEO-IDS01A4, this one contains SPSGRF-915. I have now adapted this program for a prototype containing the SPSGRF-868. During the initialization of the RF module, the program remains blocked on a step. Here is the problematic function:
void SPI1_Transmit(uint8_t *pTxData, uint8_t *pRxData, uint16_t Size) { /* start 8-bit transmission with DMA*/ /* Prepare RX */ /* (3) Memory address */ /* (4) Data size */ DMA1_Channel2->CCR &=~ DMA_CCR_EN; DMA1_Channel2->CMAR = (uint32_t)pRxData; /* (3) */ DMA1_Channel2->CNDTR = Size; /* (4) */ DMA1_Channel2->CCR |= DMA_CCR_EN; /* Prepare TX */ /* (8) Memory address */ DMA1_Channel3->CCR &=~ DMA_CCR_EN; DMA1_Channel3->CMAR = (uint32_t)pTxData; /* (8) */ DMA1_Channel3->CNDTR = Size; /* Data size */ DMA1_Channel3->CCR |= DMA_CCR_EN; }
Here is the line where the porgram stop
Someone can help me ?
Please explain what, exactly, you mean by that?
"the porgram stop"
Similarly.
Programs don't just "stop" - so please explain.
Why do you think this is a Keil problem? More likely, a misconfiguration of the chip ... ?
The porgram doesn't continue, it pauses. The LED that indicates the system is in operation is on. Perhaps is a misconfiguration but this configuration is oparating with the Nucleo's MCU
