Hello
I updated some components in the pack installer for Nordic Semi NRF51 Serie. Before there where examples using Softdevice S110. Now when i look at the examples in the pack installer. I only see examples for Softdevice S130 and S210 in the pack installer. How can i solve this? Or is this a known issue?
Friendly greets, Nick
Update
Also when i tried to update all the packs from the pack installer. I also keep getting a error: Cannot install Pack NordicSemiconductor.nRF_DeviceFamilyPack.8.5.0: Cannot compile SVD file(s)
I have also tried to manually import the pack or tried to use a older versions. But i keep getting the same error. Even reinstalled Keil without succes. Does anyone have a idea how to solve it?
Hi Nick, maybe you have already solved this problem (I hope so)...
I'm new using MDK and I have the same problem, How did you solve it?
Message from MDK: "Cannot install Pack Keil.STM32H7xx_DFP.2.0.0: Cannot compile SVD file(s)"
thank you Joan
