CubeMX not found error
I can not start STM32CubeMX from keil. When I clicked the green play button on the MDK, command window opens however, results with the error code 3 which implies that STM32Cube MX is not found.
Cube is already installed my computer and I can use it in order to create new projects. But, I would like to open the cube in order to use DS-5. I'm creating new C CMSIS project from the DS-5 and try to make pin configurations with STM32CubeMX.
Has anyone face this problem before?
Thank you
