Hi I'm trying to connect BP machine sunrom 4118 which gives serial output to uart can anyone help me with code and hardware connection Im using mcb1700(lpc1768).
hi i have tried that im not able to get the value and mostly not able to set the baud rate to 9600 its giving some garbage value.
Are you selecting the correct values for dlm, dll, Mulval and divaddval? Check it again as per the formula given in datasheet. Also double check the PCLK that you have configured.
