Lpc21xx pack in u vision5?
Hi i have this problem.I want to work on ARM micro controller the lpc 210x devise but i cant find the pack online for uvision5(the newest version).Can you help me>?
  • >>Can you help me?
    Did you try something basic like the Legacy Pack for ARM7 parts?
    www2.keil.com/.../
  • yes i did.But sth is not working.When i try to import them this message comes at the bottom of
    the page in the OUTPUT:
    Refresh Pack descriptions
    Check for updates
    C:\Keil_v5\ARM\CMSIS\5.0.1\ARM.CMSIS.pdsc: warning #500: pack 'ARM.CMSIS.5.0.1' is already defined in file C:\Keil_v5\ABOV\CM0_DFP\1.0.0\ARM.CMSIS.pdsc - duplicate is ignored
    C:\Keil_v5\Keil\ARM_Compiler\1.3.0\Keil.ARM_Compiler.pdsc: warning #500: pack 'Keil.ARM_Compiler.1.3.0' is already defined in file C:\Keil_v5\ABOV\CM0_DFP\1.0.0\Keil.ARM_Compiler.pdsc - duplicate is ignored
    C:\Keil_v5\Keil\MDK-Middleware\7.4.0\Keil.MDK-Middleware.pdsc: warning #500: pack 'Keil.MDK-Middleware.7.4.0' is already defined in file C:\Keil_v5\ABOV\CM0_DFP\1.0.0\Keil.MDK-Middleware.pdsc - duplicate is ignored
