Hi folks,
I'm trying to read a constant voltage through the MCP3425 ADC connected to a LPC1768 microcontroller, using the i2c 1 port. My code is based in one of the Keil i2c usage examples. I'm getting a very strange behaviour, I ended up stucked in a point in which I can't get into a conclusion: if I'm getting this issue due to the way I'm reading the channel through the microcontroller or if this behavious is normal to this ADC.
Look at the for loop inside the Firwmare.c file. I start configuring the MCP3425 address, and then I follow to a reading in a loop. The only way I found to get the two bytes of reading is setting the I2CReadLength[PORT_USED] as multiples of 2.
Firmware.c
#include <rtl.h> #include <string.h> #include <stdlib.h> #include <stdio.h> #include <math.h> #include <time.h> #include "LPC17xx.h" #include "type.h" #include "i2c.h" #define WAIT_SI while (!(LPC_I2C1->I2CONSET & (1<<3))) #define CLEAR_SI LPC_I2C1->I2CONCLR = 1<< 3 #define ACTION LPC_GPIO0->FIOSET0 = 1 #define ACTION_E LPC_GPIO0->FIOCLR0 = 1 #define ADDRESS LPC_GPIO0->FIOSET0 = 2 #define ADDRESS_E LPC_GPIO0->FIOCLR0 = 2 #define WRITE LPC_GPIO0->FIOSET0 = 1<<4 #define WRITE_E LPC_GPIO0->FIOCLR0 = 1<<4 #define READ LPC_GPIO0->FIOSET0 = 1<<5 #define READ_E LPC_GPIO0->FIOCLR0 = 1<<5 #define PORT_USED 1 extern volatile uint8_t I2CMasterBuffer[I2C_PORT_NUM][BUFSIZE]; extern volatile uint8_t I2CSlaveBuffer[I2C_PORT_NUM][BUFSIZE]; extern volatile uint32_t I2CReadLength[I2C_PORT_NUM]; extern volatile uint32_t I2CWriteLength[I2C_PORT_NUM]; int main(void) { uint32_t i; SystemInit(); I2C1Init(); I2CWriteLength[PORT_USED] = 2; I2CReadLength[PORT_USED] = 0; I2CMasterBuffer[PORT_USED][0] = 0xD0; //MCP3425 DEVICE CODE ADDRESS FROM DATASHEET I2CMasterBuffer[PORT_USED][1] = 0x18; //continuos conversion I2CEngine(PORT_USED); DELAY_ms(2000); //here i'm reading a voltage in a loop for(i=0; i < 128;i = i+2){ I2CWriteLength[PORT_USED] = 1; I2CReadLength[PORT_USED] = i+2; I2CMasterBuffer[PORT_USED][0] = 0xD1; I2CEngine(PORT_USED); DELAY_ms(2000); } while (1); }
