I'm trying out RTOS2 on STM32 Nucleo Boards
I want to know the difference between
1. Heap Declaration in Liner file or in .asm file which can be set using Keil IDE or cubemx 2. RTOS2 Global Memory Size
While testing code Both are allocated and both are consumed in RTOS2 based tasks
So how to define and which resource will reside on which Memory
Will RTOS2 resource all be allocated in Global Memory or it requires Heap in addition
Since I change the heap size to 0 RTOS2 fails
So what is the relation between Heap Size and Global Memory in RTOS2 Config
