I am using the KEIL MDK-5.25, assembly. The project compiles without some problems, but when i see the disassembly the assembler change the inmediate value.
Assembler replace the immediate for another.
ASM code:
SBCS R2,R1 ;R2=0xFFFFFFC7 SUBS R2,#0xC7 ;R2=0xFFFFFF00 LSLS R2,#20 ;R2=0xF0000000
Disassembly code:
517: SBCS R2,R1 ;R2=0xFFFFFFC7 0x000006BA 418A SBCS r2,r2,r1 518: SUBS R2,#0xC7 ;R2=0xFFFFFF00 0x000006BC 3A00 SUBS r2,r2,#0x00 519: LSLS R2,#20 ;R2=0xF0000000 0x000006BE 0512 LSLS r2,r2,#20 520: MOVS R4,#28 <\pre> The value #0xC7 replaced to #0x00. And this brings a wrong result. This only comes when i make the debugger with the microcontroller. When i use the simulator comes right!!
517: SBCS R2,R1 ;R2=0xFFFFFFC7 0x000006BA 418A SBCS r2,r2,r1 518: SUBS R2,#0xC7 ;R2=0xFFFFFF00 0x000006BC 3AC7 SUBS r2,r2,#0xC7 519: LSLS R2,#20 ;R2=0xF0000000 0x000006BE 0512 LSLS r2,r2,#20 <\pre> Somebody saw something simlar?
Disassembler will read the actual memory contents and decode instructions. Typically you will see the original line as written in the assembler followed by the decoded instruction.
The simulator shows expected results which indicates that the assembler generated correct code.
Most likely there is a problem on your target since the memory contents at address 0x000006BC which should be 0x3AC7 is for some reason 0x3A00 (ex: flash programming issue, …).
Thankyou Rostohar.
Exately, also I thinked that was a problem with the target. But I made the tests with another chip, other programmer, also load the codde with Atmel Studio and hapens the same problem. There is a interesant thing, when i load the .HEX the code is correct! When I make the debbug. the KEIL loads the .axf, and the ploblem hapens. but the .axf i can not read.
.HEX:
:1006A0000A4612BA0A4352BAD2BA91422ED105234F :1006B000DA4140BF0120024052428A41C73A120546 :1006C0001C24E2411146464B1970197809030909A7
Bestregards.
Cabral
