Is there a way to get more detail on the error?
Check stack settings in RTX_Config_CM.c The system most likely failed to create system threads.
I am facing the same problem running the Network middleware with CMSIS-RTX5, RTOS2 API. Were you able to resolve?
What are the settings required in RTX_Config.h (RTOS2)
Regards, Tushar H.
