Hi everyone. I need your help to solve this issue. I am using a XC164CS microcontroller to run an aplication. The next aplication code toggles a P9.0 pin every 8 seconds.
#include <XC164.h> #define T2INT 0x22 #define GPT1_TIMER_2 2 sbit led = P9^0; void GPT1_vInit(void); void MAIN_vUnlockProtecReg(void); unsigned char second; void main (void) { MAIN_vUnlockProtecReg(); // unlock write security PLLCON = 0x7D54; // load PLL control register GPT1_vInit(); // initialize Timer 2 PSW_IEN = 1; DP9 = 0x0001; // load direction register while(1); } void GPT1_viTmr2(void) interrupt T2INT using RB_LEVEL15 { second++; if(second == 8) { second = 0; led =! led; } GPT12E_T2 = 0x8170; // load timer 2 register to interrupt every 1 sec }
When I declare unsigned char idata the "second" variable, the application works properly. (This variable is alocated in on chip ram). However if i just declare unsigned char (external memory) the appliction doesn't work. The pin doesn't toggle. I have off-chip SRAM connected through an 16 bit multiplexed bus. Below I show you some configuration and setup.
What could be the problem? Thank you very much.
subefotos.com/.../
