I am using an STM32F437 microcontroller with MDK-ARM V5 and Keil’s middleware libraries. Ethernet is working OK but I would now like to add Wifi support. This will involve adding a Wifi chip. Does anyone have any experience in doing this and know whether it is possible to still use Keil’s stack with these chips. Clarinox offer a solution but this involves switching to the lwIP stack. I would like to carry on using Keil’s stack if possible. Ideally I want to switch between Ethernet and Wifi at runtime. Any ideas/suggestions most welcome.
Thanks.
Check with http://www.whiznets.com
This is what they have on their web on the below link "integrate your own network stack to WiFi driver stack library" www.whiznets.com/.../wifi-starter-kits.html
As you can see here http://www.keil.com/support/docs/3802.htm , currently the MDK Middleware Network component does not support Wifi module yet.
Is ARM MDK still does not support Wifi?
