RTX5 and network BUG??!?
Hi all,
After some hours I decided to start a new empty project with default configuration like this
1. New uVision project
2. STM32F107RC as CPU
3. Selected the next components: 3.1 RTX5 (library) then resolve 3.2 CMSIS driver -> Ethernet MAC and Ethenrnet PHY DP83848C then resolve 3.3 Network IPV4 release 3.4 Interface ETH0 set to 1 3.5 UDP sockets
4. Configure ethernet in RTE_Devices.h with RMII
5. Added a user code template CMSIS->KeilRTX5 'main'
6. Add the setStart function to main. Now main looks like this
 * CMSIS-RTOS 'main' function template
#include "RTE_Components.h"
#include  CMSIS_device_header
#include "cmsis_os2.h"
#include <rl_net.h>
#ifdef RTE_Compiler_EventRecorder
#include "EventRecorder.h"
#endif
 * Application main thread
void app_main (void *argument) {
  for (;;) {}
int main (void) {
  // System Initialization
  SystemCoreClockUpdate();
  // Initialize and start Event Recorder
  EventRecorderInitialize(EventRecordError, 1U);
#endif
  osKernelInitialize();                 // Initialize CMSIS-RTOS
  netInitialize ();
  osThreadNew(app_main, NULL, NULL);    // Create application main thread
  osKernelStart();                      // Start thread execution
  for (;;) {}
All the configurations are at default values. If I start the application in debug a HardFault exception is trowed, the fault log shows "INVSTATE" bit set.
No matter where the 'netInitialize' is called, before or after any function or inside the thread, the exception is trowed. Also tried to change all stacks to sizes to the highest possible value and the exception is trowed.
Also tried to use the event recorder and the network component to debug and all is ok, no errors found.
Thanks all
  • netInitialize() must lack resources to perform all its duties.
    ARM_ETH_MAC_Initialize() or ARM_USART_Initialize() require callback functions.
    Sometimes a NULL is passed into these functions, and this causes the network init to fail in this type of fault. Look in the CMSIS network documentation to learn more about these functions:
    www.keil.com/.../index.html
    INVSTATE can also happen when an application tries to use an area of memory that has not been initialized or not initialized correctly for its use. For example, with external RAM, at least for some earlier ST devices, they require a macro "DATA_IN_ExtSRAM" to be defined before initializing this memory, automatically in a function before main().
    Was the MPU enabled?
  • Hi,
    First want so say the real place for the netInitialize is in the thread, of course I tried this.
    No need to write any callback, this is done by the library... you could need this if you want to change any default.
    I have not using external ram,.... mpu enabled?
  • Forget about the MPU. I don't think you have to worry about this fct with STM32F1's...
    Did you increase stack size in startup file?
    www.keil.com/.../nw_resource_requirements.html
    If issue persists, try following the application note for faults:
    http://www.keil.com/appnotes/files/apnt209.pdf
    At the end, it tells you how to find an address that is connected to the fault.
    Setting a breakpoint there, and looking at the call stack may provide more clues.
  • The CMSIS driver is where these callback functions could be defined, rather than a middleware library. Otherwise, the user is responsible to define callback functions.
    netInitialize() should be called after osKernelStart()
    (if the user chooses to explicitly call osKernelInitialize() and osKernelStart()),
    because it will start at least one new thread.
  • Hi,
    I tried to solve the problem in my real application, not the example posted. My application mix CMSIS and initialization of peripherals with CubeMX, for any reason if I use microLIB the program runs ok but when use standard C Library the program crashes. Finally I rewrite the application only with CMSIS library without using code from CubeMXand works ok... I think there is a problem mixing CubeMX and CMSIS but the compiler don't show any warning or problem.
