MCBSTM32F400 http server example problem
Hi guys,
I am using MCBSTM32F400 development board to lear http server application. There is a example project in Keil called "http server ipv4/ipv6 (MCBSTM32F400)". I use this example and download to the board. Then I use a Ethernet cable to connect my PC and board directly as in file abstract says below:
/***Abstract file in the project***/
This is a HTTP_Server example running on Network Dual Stack.
Detailed description is available on:
www.keil.com/.../_compact__web__server__example.html
Use this example to connect an evaluation board to a LAN with router.
You may also connect an evaluation board to PC directly using a direct
or crosslink network cable.
To connect to the HTTP server you can use auto-assigned IPv6 address,
IPv4 address assigned by the DHCP server or NBNS resolved local host name.
To test this example, open your web browser and enter the
address http://mcbstm32f400/ or http://<boards IP address>
IPv4 and IPv6 addresses are printed on display of evaluation board.
Default user : admin
Default password: <none>
The HTTP_Server example is available for multiple targets:
MCBSTM32F400 V1.1: Standalone application for MCBSTM32F400 V1.1 board using ST802RT1 Ethernet PHY. Program code is loaded into on-chip flash.
MCBSTM32F400 V1.2: Standalone application for MCBSTM32F400 V1.2 board using KSZ8081RNA Ethernet PHY. Program code is loaded into on-chip flash.
/***End of Abstract file***/
However, both my PC and board can not get ip v4 address, and no matter I input host name or ip v6 address in browser, I couldn't make it works. Anything I did wrong?
Thanks a lot.
Mark
