Hi, I am carrying out project on home automation (monitoring and security).I need to send the senors (IR,PIR,MQ-6gas senor) output to the control unit using rf transmitter and receiver and that will be displayed on display using microcontroller so suggest me a rf transmitter receiver module tht is fit for interfacing wth microcontroller and should be of 4 channel.Reply ASAP plzz
Thank you
SiLabs have '51 MCUs with RF transmitter/receivers
Thanks for ur suggestion.But i need a rf transmitter and receiver tht can be interfaced with microcontroller with four channel and it should not be a part of microcontroller model.reply asap tqew
I have a very good suggestion for you but i am too busy at the moment to type out the part number.
I will give you the detail tomorrow.
Or maybe the day after.
But if I remain busy my reply will have ti be delayed further.
Happy waiting.
They also have ARM Cortex-M MCUs with RF transmitter/receivers
They also have RF transmitter/receivers with no MCU
www.silabs.com/.../proprietary
anyhow a good place for device search is the DigiKey website
why on earth not
other distributors (and silicon manufacturers) are available.
other distributors (and silicon manufacturers) are available. absolutely, I often use the DigiKey website for finding the component and buy elsewhere. Just I find the DigiKey search engine the best for component search.
the likes of ebay and aliexpress have got literally bucketloads of cheap arduino modules for these primary skool projects.
