USB connection failure when device is in USB Host mode
Hello, Keil users,
I am trying to get a connection between LPC4357 and a U-Blox modem over USB.
First of all I connected the modem to PC, it was recognized correctly, it adds 6 COM ports.
I have looked at examples provided by Keil, and created a simple project where I initialize my MC as USB CDC Host. For the second test I took
another device based on the same MC that is initialized as a USB CDC Device and connected to a USB Host, created at a previous step, the connection between two LPC4357 MC is successful.
The next step was to try the connection with a modem. For debug purposes Event recorder was enabled. The problem is that I am getting PipeReceiveFailed event, of length 15, and error is 64. This error happens when I am trying to get the device status.
I have looked for this error and it is "Transfer handshake was stall".
Are there hints how to prevent this error and to establish the communication correctly?
I attach the screenshot of the event recorder
https://ibb.co/d1RniH
Here is the code listing
        usb_status = USBH_Initialize(0);
        if (usb_status != usbOK)
                printf ("InitFailure!\n");
        while(1){
                con = (USBH_CDC_ACM_GetDeviceStatus(0) == usbOK);
                if (con ) {
                        connected = true;
                        if (con == true) {
                                con_last = true;
                                LED_On(0);
                                USBH_CDC_ACM_Send(0, buff, 3);
                        } else {
                                con_last = false;
                                LED_Off(0);
                        } else {
                                osDelay(1000);
  • Quite possibly, there were other things too.
    Are you sure that the LPC4357 and/or the Keil stack supports suck a complex device...?
  • Hi Andrii,
    this will not quite work the way you imagined it.
    Such device, as the one you have are called composite devices, and for such device you have to write your own driver, meaning you have to use Custom Class capability of the USB Host.
    Also, a big problem with such device is that they have a lot of functionality implemented as proprietary, meaning there is no standard for such device, but manufacturers decide which interface they are using for what.
    Usually, manufacturer of such a device provides a driver for MS Windows, however to be able to talk to such a device with embedded device you will have to get specification of that device from manufacturer on how this device is driven regarding USB interfaces, and this might be an insurmountable problem.
    Best regards, Milorad
  • Hello Milorad Cvjetkovic,
    thanks for your reply, I have used a trace program(Usblyzer) for checking USB communication between PC and modem, what it is happening in the background and then implemented it in a custom class, as you said, it works.
    Thanks.
  • Hello Andrew Neil,
    I did double check of the requirements, and have found that my idea is not possible in a way I planned it, bcos USB0 with high speed of MC is already used, and to use USB1 with full speed will load my MC too much (in Full speed modem the buffer size is 64 bytes and delays between tranfers are too long), that it will stack with this job all the time, so I will need to redesign my system with this modem.
    Thanks for your answer!
