Maybe my question is not unique, sorry for that, but I did't find a solution.
So I gonna ask:
How do I use labels in binary expressions?
For example:
AREA STACK, NOINIT, READWRITE SPACE 0x100 ; Here I declare stack data array STACK_TOP ; Here I place label, that pointing at the end of the stack ; So I can use STACK_TOP in my vector table AREA HEAP, NOINIT, READWRITE SPACE 0x100 ; Here I declare some heap ; HEAP_END ; Here my heap ends ; ; Here I place some data variables ; ... ; Some code MOV32 param1, (SRAM_BB_BASE :OR: (HEAP_END << 5) :OR: (5 << 2)) ; I want to use bit-bang with my first data variable, but asm compiler tells me ; ;main.s(111): error: A1586E: Bad operand types (PC Relative, Constant) for operator OR;
Same thing when I try to mov label from CODE area and clear bit[0] with :AND:.
How should I convert PC Relative to absolute address (constant)?
