Dear KEIL Team,
I have a problem when build target. I use KEIL UVersion 5. Do I need to buy the full version?
Below is Build Output: Build target 'Debug Version'
linking... BL51 BANKED LINKER/LOCATER V6.22.2.0 - SN: Eval Version COPYRIGHT ARM Germany GmbH 1987 - 2017 ".\Release\main.obj", ".\Release\HostCtl.obj", ".\Release\SysFunction.obj", ".\Release\Hardware.obj", ".\Release\HDCP.obj", ".\Release\Nodes.obj", "..\SHA.Lib", ".\Release\Edid.obj", ".\Release\AudioController.obj", ".\Release\CecCtl.obj", "..\..\EPF021HCI\Release\EPF021HCI.LIB", "..\..\CEC\EPCCLib_PLAYER.LIB", ".\Release\MHL_If.obj", ".\Release\MHL_Bus.obj", ".\Release\VideoController.obj", ".\Release\SMBUS_P0.obj", ".\Release\VideoScaler.obj" TO ".\Release\Project" REGFILE (.\Release\Project.ORC) NOPRINT RAMSIZE(256) DISABLEWARNING (16) NOOVERLAY CODE( 0X0000-0XEFFF ) XDATA( 0XF400-0XFFFF ) *** FATAL ERROR L251: RESTRICTED MODULE IN LIBRARY NOT SUPPORTED MODULE: ..\..\EPF021HCI\Release\EPF021HCI.LIB (TIMER) Target not created. Build Time Elapsed: 00:00:01
Yes
Ok. Thanks
if your chip is SiLabs, no
