I am attempting to execute code out of RAM.
I proved the concept by writing a simple LED blinky function and running it out of RAM. I actually got it work on the MCB2300 Dev Board.
My method is as follows - create an array/buffer to allocate some space on the stack (SRAM). The buffer must be large enough for the function and I get the size from the memory map. I then page align the buffer and copy the function into the buffer and execute.
unsigned char codeBuffer[1024]; unsigned char *alignedCodeBuffer = (unsigned char*)( ((int)codeBuffer + 256) & 0xFFFFFF00 ); void (*functionPointer)(void) = (void(*)(void))alignedCodeBuffer; memcpy( (void*)alignedCodeBuffer, (void*)&toggleLed1, sizeof(codeBuffer) - 256 ); VICIntEnClr = 0xFFFFFFFF; //Disable all Interrupts functionPointer();
The problem now is that I moved this code to my real application and I am getting taken to
DAbt_Addr DCD DAbt_Handler
I need my code to have relative addressing. Looking through the disassembly window, I see absolute addressing, or, references to the FLASH address space. Notice the 0x0000D67C.
0x0000D67C E1B01000 MOVS R1,R0 0x0000D680 E2400001 SUB R0,R0,#0x00000001 0x0000D684 1AFFFFFC BNE 0x0000D67C
Am I doing something wrong besides the obvious that it isn't working.
Is there a compiler flag I am missing?
Another possible solution is to replace the BNE instruction with a combination of other assembly instructions to move the PC back a few times.
Looking through the disassembly window, I see absolute addressing, No, you don't. You see PC-relative addressing, which the disassembler is helpfully displaying as the target address it resolves to. The clue is in the difference between the disassembly and the actual code bytes to the left of it.
The more likely reason for you ending up in the Abort handler would be that you got your alignment wrong. Remember that Thumb code is defined by being at odd addresses.
I figured this out earlier today and furthermore, I found out how to map entire files into RAM rather than FLASH. This solved my issue. I now have a new issue that I am currently typing up. Hopefully you may have some insight on it.
I was able to remap this by using the graphical interface, which I was surprised. Options for the file along with Target options helped immensely.
