Hii,
i know that windows don't have native support for CDC/NCM, i am using keil cdc/ncm class with windows as host so kindly suggest me some recommended drivers for windows(wheather its from keil or any other third party).
Hi, While waiting for replies here, you can ask also in the Microsoft drivers forum:
social.msdn.microsoft.com/.../home
They may suggest a Windows in-box driver or give useful tips.
-- pa
If you want to test USB Device CDC example projects from Pack Installer, the corresponding USB CDC drivers for windows are included in the example projects.
Read Abstract.txt inside these example projects for more details, as written here www.keil.com/.../dev_cdc_tutorial.html
If you write your own USB device CDC program, then you should write your own windows CDC driver.
I am not talking about CDC/ACM class(i.e virtual comport). I am talking about CDC/NCM class(i.e virtual Ethernet adapter).
