I installed MDK5.24a and copied a HTTP Server compact for FRDM-K64 but uVision complains saying below error. Can someone help? Application Note 271 talks about using this web server on FRDM-K64. How they got this working, if this library is not supported in this version?
Error #540: 'Keil.MDK-Pro::Network:CORE:Release:6.4.0' component is not available for target 'MK64FN1M Flash'
Maybe see this:
http://www.keil.com/support/docs/3919.htm
Thank you. It helped to remove compiler errors from 19 to 2. It says below file missing. I followed migration instructions but it seems it requires lot of code changes. Any idea where this include file can be found?
compiling fsl_gpio_driver.c... compiling fsl_enet_hal.c... C:\Keil_v5\ARM\PACK\Keil\Kinetis_SDK_DFP\2.2.0\platform\hal\inc\fsl_enet_hal.h(37): error: #5: cannot open source input file "core_cmInstr.h": No such file or directory #include "core_cmInstr.h" C:\Keil_v5\ARM\PACK\Keil\Kinetis_SDK_DFP\2.2.0\platform\hal\src\enet\fsl_enet_hal.c: 0 warnings, 1 error
Check \ARM\Pack\ARM\CMSIS\4.1.1\CMSIS\Include \ARM\Pack\ARM\CMSIS\x.x.x\CMSIS\Include
See if the file is there,
If it is, add the path to your include path.
No it's not there in any 5.x.x\CMSIS\Include
I found the file in below directory but it adds tons of errors. I also notice crash when I press build button. I can't see the crash message.
C:\Keil_v5\ARM\PACK\Keil\Kinetis_SDK_DFP\2.2.0\platform\CMSIS\Include
Bad news:
github.com/.../Overview.txt
Removed: deprecated files core_cmfunc.h, core_cminstr.h, core_cmsimd.h.
Maybe: Delete the include of core_cmInstr.h
ARM CMSIS 4.5.0
github.com/.../core_cmInstr.h
Thanks much for help John. I was able to play trick and it worked. I couldn’t remove file but I was able to create blank file and all compiled successfully and run the web server on board.
