no flying leads, no shorts, no static - suddenly my device behaves this way
is this something I could have done
is there a cure,
I build a new project for check - same error
from manual: Device could not be powered up Debug block on the device could not be powered. Debug block on the target is not working properly. Mainly caused by target problems: debug block not powered and clocked properly.
Does your code put the chip into some low-power "sleep" mode?
This often renders the debug inaccessible ...
Per your username, WHICH CHIP?
Per your username, WHICH CHIP? OUCH :)
LPC11U24
sorry bout the double, the site did not react to a posting aqlthough it had taken it
Unbricking LPC11U24 or LPC1768
os.mbed.com/.../Unbricking
-- Are you Erik? ( Silicon Labs <-> NXP )
os.mbed.com/.../Unbricking thanx
-- Are you Erik? ( Silicon Labs <-> NXP ) yes
