HELLO SIR Can you please send me a code for finger print based vehicle starter.
No. But maybe a voice print based engine starter?
Here's one line to get you started. Just put the required other parts before and after.
break;
No charge for this first part.
If you are unable to perform your assigned task, perhaps you need to look for another line of work or study?
With a purchased commercial-grade finger print sensor, the task is basically trivial.
Without one, it's closer to research-level - not easy to prove the detection probability of a home-designed sensor so it doesn't allow 10% of the human population.
Add this to your 8051 via a serial UART...
www.ebay.com/.../252630575387
Don't worry, we all need source code sometimes, its important you are open about it and talk about it :)
This is why you tend to learn to swim in a swimming pool rather than jumping into the middle of an ocean and start screaming.
Learn to break the problem into smaller steps, and learn how to use a search engine. Find a company the licences technology to perform the tasks you can't.
This sounds like a school project, talk to your supervisor, it is what he's paid for.
I didn't realize we can just ask for free source code...
I need source code for a World Domination Machine I got on eBay.
The system will use an Arduino and "STMCubeMX" program to control it from my phone.
The development is a PC with Windows 10 and a keyboard and a Logitech mouse.
I started with the code "A Coda" suggested but it has errors.
code so far:
case OCEANIA: break; // (c) A Coda 14-Jan-2017 15:50 GMT
Also, I need it by Tuesday. Thanks in advance.
--Cpt. Vince Foster 2nd Cannon Place Fort Marcy Park, VA
Dominatrix module mailed. Will interface over MIL-STD-1553B or optionally MIL-STD-1773. Can on request be adapted for GOST R 52070-2003, GJV289A or Digibus free of charge.
I got the module. Its kinda sticky and [weirdly] slippery at the same time.
Not sure if you understood my World Domination needs correctly. This seems to be a module for a single Master/Slave operation. My requirement is to have one Master with 7.6B+ Slaves.
What is the purpose of the function int16_t PayUpFront( uint64_t ccNo, uint16 PinNo ); ? It seems to be required to access all your other Dominatrix functions. Can I pass it NULLs?
Also, I can't find a "MIL-STD-1553B" plug-in for the Arduino nor the STMCubeMX software.
Ah - this module is actually based on some code I located on a USB thumb drive someone had luckly dropped just outside my doorstep. There was some source code but mostly binary data, and an auto-run boot loader.
I like to call it a "she" since it seems to have a lot of personality. I haven't fully grasped all functionality but did find some references to a general's daughter, a Cpt Elisabeth Campbell etc from a link to stux.net in the string constants section.
I guess that still unidentified general is somehow the reason for the avionics bus support. But there are lots of interface code still not properly analyzed - seems to be a plane jane ISO 11898-2 in there too, so this baby most probably can talk with just about anything. I'm pretty sure we will be able to find a common interface for that Arduino. Properly interfaced she should be collecting herself a proper hive of drones. Make sure you have a flat-fee subscription - I almost got a network outage when she slipped into my movie store. After the initial bootstrap your network feels will go down - she'll find alternative routes. Anyway - I also found a reference to www.itk.ntnu.no/.../Message_30.pdf indicating that there may be more communications code I still haven't fully decoded. Maybe just try to reinstall?
However, she's sneaky. Make sure all rubber seals are properly inspected and replaced before use. If she's sticky then you have a leak somewhere. She might have own ambitions, and also seems to gossip - I caught her sending snippets of The China Syndrome, Silkwood and Dr. Strangelove to some unknown friend, so she's definitely a movie lover.
One thing that puzzles me a bit was a note on that stux.net site about "watch the steganography". But probably not important enough to spend time on.
The int16_t PayUpFront( uint64_t ccNo, uint16 PinNo ) function? Oops. Seems like the automatic install scripts must have failed. Have shipped an updated version that will not ask. You into bitcoins, by any chance?
You made my day. Jättebra, tack så mycket.
