hello, my c/c++ compiler stopped working while i have my program in microvision3.I am using windows 10. i welcome your valuable suggestions.
DID YIU. BY DELETER THE COMPILER.
CHECK THE PATHS FOR WEADES AND VIRTUESES.
Is uV3 compatible with Win10?
Did you install the software on the Win10 system or did you upgrade an older system to Win10?
Try compatibility mode or appropriate OS.
Whats the error messgage ?
or did the compiler just vanished ?
Is uv3 compatible with windows 10
Are you running in compatibility mode
Can you tell us what the error message is. Your description makes it sound like the software has vanished.
Also. Is it a mew installingtion of windows 1o or did you do a free upgrats.
How many times did the compliier work before id vanished
Do you use a legacy keyboard
What directory do you store the project files too
