Hi all,
Really hope you guys can help – I’m running late with this project and may have no choice but to change compilers if this isn’t resolved soon.
I am using MDK-Lite with a Segger JLink for a STM32L031 target. The code can be successfully complied/downloaded/executed on the target without issues, however I cannot set breakpoints at all. When not in debugging mode, I can set breakpoints but they turn into greyed-out ‘!’ symbols when I start the debugger. I have debug information checked in the output tab.
IDE-Version: µVision V5.24.2.0
Tool Version Numbers: Toolchain: MDK-Lite Version: 5.24.1 Toolchain Path: C:\Keil_v5\ARM\ARMCC\Bin C Compiler: Armcc.exe V5.06 update 5 (build 528) Assembler: Armasm.exe V5.06 update 5 (build 528) Linker/Locator: ArmLink.exe V5.06 update 5 (build 528) Library Manager: ArmAr.exe V5.06 update 5 (build 528) Hex Converter: FromElf.exe V5.06 update 5 (build 528) CPU DLL: SARMCM3.DLL V5.24.1 Dialog DLL: DARMCM1.DLL V1.18.0.0 Target DLL: Segger\JL2CM3.dll V2.99.26.0 Dialog DLL: TARMCM1.DLL V1.13.0.0
You have turned off optimisations? If not, the executable code might not directly match the source.
Put the optimization level to -O0 in Options for target -> C/C++ tab
It should help you.
I tried both suggestions but nothing has changed - still no breakpoints
Just to clarify, I can set breakpoints in the disassembly window but not in the source window. When I stop the debugger I can then set breakpoints in the source.
There MUST be a setting or a symbol file that is not being loaded correctly.... I find it hard to believe that this is not a known issue with this compiler - setting of breakpoints is such a fundamental thing!
in the build output window it displays: Hardware-Breakpoints: 4 Software-Breakpoints: 8192 Watchpoints: 2
Seems this is an integration issue between Segger's JLink and the MDK IDE. The issue is resolved by downloading/replacing a segger DLL in the Keil directory.
www.segger.com/.../
Strongly suggest that Keil update the MDK download to include the new DLL above - will save people a lot of frustration
What do you mean by, "stop the debugger" ?
I think it is expected/intended behaviour that breakpoints cannot be set while the target is running ?
