We had run our STM32F207 Hardware over night with a battery. Now the battery is empty and we can't flash the STM32F207 with Ulink Me (of course with proper powersupply).
Ulink says: Error: Flash Download failed - "Cortex-M3"
We can check the RDP register: the value is 0xff so we are in RDP Level 1.
We try to flash the STM32F207 with the " erase full chip"-Option but Full Chip Erase failed. If we try to flash an other STM32F207-Hardware this works fine.
So we tried to flash \Keil\ARM\Boards\Keil\MCBSTM32F200\Blinky with OPTs set to Level 0 but we can't flash it.
So we have 2 Questíons
How is it posible that the Level change form 0 to 1 without any line of code to do this? How can we disable the Read Out Protection with Ulink Me?
More likely a power/connectivity issue than one where Read Out Protection being engaged.
Use the STLink application to adjust the option bytes, returning you to level 0. This will implicitly erase internal flash.
For this, you need a STLink, AFAIK. Maybe you can use a cheap STM32F0 discovery as a programmer.
Are you using the "EEPROM Emulation" in Flash?
To fix, I would second the idea of using an ST-Link and ST's ST-Link Utility.
I have installed the STM ST-LINK Utility Software.
It shows that Read Out Protection Level is set to 1. If I change it to 0 I get the message that the Option bytes could not set.
11:27:09 : ST-LINK SN : 48FF6A066765565147401467 11:27:09 : ST-LINK Firmware version : V2J23S4 11:27:09 : Connected via SWD. 11:27:09 : SWD Frequency = 4,0 MHz. 11:27:09 : Connection mode : Normal. 11:27:09 : Debug in Low Power mode enabled. 11:27:09 : Device ID:0x411 11:27:09 : Device family :STM32F2xx 11:27:09 : Can not read memory! Disable Read Out Protection and retry. 11:27:29 : Could not set Option bytes! Please reset the target and retry. 11:27:31 : Can not read memory! Disable Read Out Protection and retry.
"I get the message that the Option bytes could not set"
Can it do a full chip erase?
No it fails
Oh dear.
But you have now eliminate the Keil tools - so now time to speak to ST and/or your distributor FAE about this ...
