Problem calculator program
I have a big problem with programming for Board MCB2300 and Micro LPC2388.
I want to design a calculator and this is my code :
#include <lpc23xx.h>
#include <stdio.h>
// Alphanumeric LCD Module functions
#include <alcd.h>
// Declare your global variables here
int row[4]={0xfe,0xfd,0xfb,0xf7},num1=0,num2=0;
char buffer[16];
bit flag2=0;
bit flag=0;
void setNum(int n);
void sum();
void mul();
void dev();
void sub();
void main(void)
{ int i=0,mode=0;
// Declare your local variables here
// Input/Output Ports initialization
// Port A initialization
// Func7=In Func6=In Func5=In Func4=In Func3=In Func2=In Func1=In Func0=In
// State7=T State6=T State5=T State4=T State3=T State2=T State1=T State0=T
PORTA=0x00;
DDRA=0x00;
// Port B initialization
PORTB=0x00;
DDRB=0x00;
// Port C initialization
// Func7=In Func6=In Func5=In Func4=In Func3=Out Func2=Out Func1=Out Func0=Out
// State7=T State6=T State5=T State4=T State3=0 State2=0 State1=0 State0=0
PORTC=0xff;
DDRC=0x0F;
// Port D initialization
PORTD=0x00;
DDRD=0x00;
// Timer/Counter 0 initialization
// Clock source: System Clock
// Clock value: Timer 0 Stopped
// Mode: Normal top=0xFF
// OC0 output: Disconnected
TCCR0=0x00;
TCNT0=0x00;
OCR0=0x00;
// Timer/Counter 1 initialization
// Clock value: Timer1 Stopped
// Mode: Normal top=0xFFFF
// OC1A output: Discon.
// OC1B output: Discon.
// Noise Canceler: Off
// Input Capture on Falling Edge
// Timer1 Overflow Interrupt: Off
// Input Capture Interrupt: Off
// Compare A Match Interrupt: Off
// Compare B Match Interrupt: Off
TCCR1A=0x00;
TCCR1B=0x00;
TCNT1H=0x00;
TCNT1L=0x00;
ICR1H=0x00;
ICR1L=0x00;
OCR1AH=0x00;
OCR1AL=0x00;
OCR1BH=0x00;
OCR1BL=0x00;
// Timer/Counter 2 initialization
// Clock value: Timer2 Stopped
// OC2 output: Disconnected
ASSR=0x00;
TCCR2=0x00;
TCNT2=0x00;
OCR2=0x00;
// External Interrupt(s) initialization
// INT0: Off
// INT1: Off
// INT2: Off
MCUCR=0x00;
MCUCSR=0x00;
// Timer(s)/Counter(s) Interrupt(s) initialization
TIMSK=0x00;
// USART initialization
// USART disabled
UCSRB=0x00;
// Analog Comparator initialization
// Analog Comparator: Off
// Analog Comparator Input Capture by Timer/Counter 1: Off
ACSR=0x80;
SFIOR=0x00;
// ADC initialization
// ADC disabled
ADCSRA=0x00;
// SPI initialization
// SPI disabled
SPCR=0x00;
// TWI initialization
// TWI disabled
TWCR=0x00;
// Alphanumeric LCD initialization
// Connections specified in the
// Project|Configure|C Compiler|Libraries|Alphanumeric LCD menu:
// RS - PORTA Bit 0
// RD - PORTA Bit 1
// EN - PORTA Bit 2
// D4 - PORTA Bit 4
// D5 - PORTA Bit 5
// D6 - PORTA Bit 6
// D7 - PORTA Bit 7
// Characters/line: 16
lcd_init(16);
while (1) { // Place your code here for(i=0;i<4;i++) { PORTC=row[i]; if(i==0) { if(PINC.4==0) { while(PINC.4==0) {} lcd_putchar('7'); setNum(7); } if(PINC.5==0) { while(PINC.5==0) {} lcd_putchar('8'); setNum(8); } if(PINC.6==0) { while(PINC.6==0) {} lcd_putchar('9'); setNum(9); } if(PINC.7==0) { while(PINC.7==0) {} if(flag==0 || flag2==1) { flag=1; lcd_putchar('/'); flag2=0; mode=1; } } } else { if(i==1) { if(PINC.4==0) { while(PINC.4==0) {} lcd_putchar('4'); setNum(4); } if(PINC.5==0) { while(PINC.5==0) {} lcd_putchar('5'); setNum(5); } if(PINC.6==0) { while(PINC.6==0) {} lcd_putchar('6'); setNum(6); } if(PINC.7==0) { while(PINC.7==0) {} if(flag==0 || flag2==1) { flag=1; flag2=0; lcd_putchar('*'); mode=2; } } } else { if(i==2) { if(PINC.4==0) { while(PINC.4==0) {} lcd_putchar('1'); setNum(1); } if(PINC.5==0) { while(PINC.5==0) {} lcd_putchar('2'); setNum(2); } if(PINC.6==0) { while(PINC.6==0) {} lcd_putchar('3'); setNum(3); } if(PINC.7==0) { while(PINC.7==0) {} if(flag==0 || flag2==1) { flag=1; flag2=0; lcd_putchar('-'); mode=3; } } } else { if(i==3) { if(PINC.4==0) { while(PINC.4==0) {} num1=0; num2=0; flag=0; flag2=0; lcd_clear(); } if(PINC.5==0) { while(PINC.5==0) {} lcd_putchar('0'); setNum(0); } if(PINC.6==0) { while(PINC.6==0) {} switch(mode) { case 1: { dev(); break; } case 2: { mul(); break; } case 3: { sub(); break; } case 4: { sum(); break; } } } if(PINC.7==0) { while(PINC.7==0) {} if(flag==0 || flag2==1) { flag=1; flag2=0; lcd_putchar('+'); mode=4; } } } } } }
void setNum(int n)
if(flag==1) { num2=(num2)*10; num2+=n; } else if(flag==0) { num1=(num1)*10; num1+=n; }
void sum()
{ int answer=num1+num2; num1=answer; num2=0; lcd_clear(); sprintf(buffer,"%d",answer); lcd_puts(buffer); flag2=1;
void mul()
{ int answer=num1*num2; num2=0; num1=answer; lcd_clear(); sprintf(buffer,"%d",answer); lcd_puts(buffer); flag2=1;
void dev()
{ int answer=num1/num2; num2=0; lcd_clear(); num1=answer; sprintf(buffer,"%d",answer); lcd_puts(buffer); flag2=1;
void sub()
{ int answer=num1-num2; num1=answer; num2=0; lcd_clear(); sprintf(buffer,"%d",answer); lcd_puts(buffer); flag2=1;
I have errors about afx and lcd ,When I compile it.
Can you please help me?
what do I need?
Please correct this Cod for me.
I want to use the Keypad.
Thank You
  • one more poster that can't read instructions.
  • I've long since given up taking these posts seriously.
    And with this one, we can't even mention the part about teaching a man to fish; i.e.,
  • Excuse me, If I can not speak English verywell.
    Because I can speak German(Deusch).
    #include <stdio.h>
    #include <alcd.h>
    char buffer[16];
    bit flag2=0;
    bit flag=0;
    void setNum(int n);
    void sum();
    void mul();
    void dev();
    void sub();
    void main(void)
    { int i=0,mode=0;
    PORTA=0x00;
    DDRA=0x00;
    PORTB=0x00;
    DDRB=0x00;
    PORTC=0xff;
    DDRC=0x0F;
    PORTD=0x00;
    DDRD=0x00;
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    TCCR1A=0x00;
    TCCR1B=0x00;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    // INT0: Off
    // INT1: Off
    // INT2: Off
    MCUCR=0x00;
    MCUCSR=0x00;
    TIMSK=0x00;
    // USART disabled
    UCSRB=0x00;
    ACSR=0x80;
    SFIOR=0x00;
    // ADC disabled
    ADCSRA=0x00;
    // SPI disabled
    SPCR=0x00;
    // TWI disabled
    TWCR=0x00;
    // RS - PORTA Bit 0
    // RD - PORTA Bit 1
    // EN - PORTA Bit 2
    // D4 - PORTA Bit 4
    // D5 - PORTA Bit 5
    // D6 - PORTA Bit 6
    // D7 - PORTA Bit 7
    lcd_init(16);
    while (1)
    for(i=0;i<4;i++)
    { PORTC=row[i];
    if(i==0)
    { if(PINC.4==0)
    { while(PINC.4==0)
    lcd_putchar('7');
    setNum(7);
    } if(PINC.5==0)
    { while(PINC.5==0)
    lcd_putchar('8');
    setNum(8);
    } if(PINC.6==0)
    { while(PINC.6==0)
    lcd_putchar('9');
    setNum(9);
    } if(PINC.7==0)
    { while(PINC.7==0)
    { flag=1;
    lcd_putchar('/');
    flag2=0;
    mode=1;
    } else
    { if(i==1)
    { if(PINC.4==0)
    { while(PINC.4==0)
    lcd_putchar('4');
    setNum(4);
    } if(PINC.5==0)
    { while(PINC.5==0)
    lcd_putchar('5');
    setNum(5);
    } if(PINC.6==0)
    { while(PINC.6==0)
    lcd_putchar('6');
    setNum(6);
    } if(PINC.7==0)
    { while(PINC.7==0)
    { flag=1;
    flag2=0;
    lcd_putchar('*');
    mode=2;
    } else
    { if(i==2)
    { if(PINC.4==0)
    { while(PINC.4==0)
    lcd_putchar('1');
    setNum(1);
    } if(PINC.5==0)
    { while(PINC.5==0)
    lcd_putchar('2');
    setNum(2);
    } if(PINC.6==0)
    { while(PINC.6==0)
    lcd_putchar('3');
    setNum(3);
    } if(PINC.7==0)
    { while(PINC.7==0)
    { flag=1;
    flag2=0;
    lcd_putchar('-');
    mode=3;
    } else
    { if(i==3)
    { if(PINC.4==0)
    { while(PINC.4==0)
    num1=0;
    num2=0;
    flag=0;
    flag2=0;
    lcd_clear();
    } if(PINC.5==0)
    { while(PINC.5==0)
    lcd_putchar('0');
    setNum(0);
    } if(PINC.6==0)
    { while(PINC.6==0)
    switch(mode)
    { case 1:
    { dev();
    break;
    } case 2:
    { mul();
    break;
    } case 3:
    { sub();
    break;
    } case 4:
    { sum();
    break;
    } if(PINC.7==0)
    { while(PINC.7==0)
    { flag=1;
    flag2=0;
    lcd_putchar('+');
    mode=4;
    void setNum(int n)
    if(flag==1)
    { num2=(num2)*10;
    num2+=n;
    } else if(flag==0)
    { num1=(num1)*10;
    num1+=n;
    void sum()
    num1=answer;
    num2=0;
    lcd_clear();
    lcd_puts(buffer);
    flag2=1;
    void mul()
    num2=0;
    num1=answer;
    lcd_clear();
    lcd_puts(buffer);
    flag2=1;
    void dev()
    num2=0;
    lcd_clear();
    num1=answer;
    lcd_puts(buffer);
    flag2=1;
    void sub()
    num1=answer;
    num2=0;
    lcd_clear();
    lcd_puts(buffer);
    flag2=1;
  • Put the source code between PRE tags, if it doesn't look good in preview mode, it won't look good when posted.
    Break the problem in to small pieces you can understand and test.
  • Look at this picture: www.danlhenry.com/.../keil_code.png
    - follow the instructions.
    If that's not clear, try following the link, "Tips for Posting Messages".
    Have you tried viewing these in Google Translate?
  • Tank You.
    #include <stdio.h>
    #include <alcd.h>
    char buffer[16];
    bit flag2=0;
    bit flag=0;
    void setNum(int n);
    void sum();
    void mul();
    void dev();
    void sub();
    void main(void)
    { int i=0,mode=0;
    PORTA=0x00;
    DDRA=0x00;
    PORTB=0x00;
    DDRB=0x00;
    PORTC=0xff;
    DDRC=0x0F;
    PORTD=0x00;
    DDRD=0x00;
    TCCR0=0x00;
    TCNT0=0x00;
    OCR0=0x00;
    TCCR1A=0x00;
    TCCR1B=0x00;
    TCNT1H=0x00;
    TCNT1L=0x00;
    ICR1H=0x00;
    ICR1L=0x00;
    OCR1AH=0x00;
    OCR1AL=0x00;
    OCR1BH=0x00;
    OCR1BL=0x00;
    ASSR=0x00;
    TCCR2=0x00;
    TCNT2=0x00;
    OCR2=0x00;
    // INT0: Off
    // INT1: Off
    // INT2: Off
    MCUCR=0x00;
    MCUCSR=0x00;
    TIMSK=0x00;
    // USART disabled
    UCSRB=0x00;
    ACSR=0x80;
    SFIOR=0x00;
    // ADC disabled
    ADCSRA=0x00;
    // SPI disabled
    SPCR=0x00;
    // TWI disabled
    TWCR=0x00;
    // RS - PORTA Bit 0
    // RD - PORTA Bit 1
    // EN - PORTA Bit 2
    // D4 - PORTA Bit 4
    // D5 - PORTA Bit 5
    // D6 - PORTA Bit 6
    // D7 - PORTA Bit 7
    lcd_init(16);
    while (1)
    for(i=0;i<4;i++)
    { PORTC=row[i];
    if(i==0)
    { if(PINC.4==0)
    { while(PINC.4==0)
    lcd_putchar('7');
    setNum(7);
    } if(PINC.5==0)
    { while(PINC.5==0)
    lcd_putchar('8');
    setNum(8);
    } if(PINC.6==0)
    { while(PINC.6==0)
    lcd_putchar('9');
    setNum(9);
    } if(PINC.7==0)
    { while(PINC.7==0)
    { flag=1;
    lcd_putchar('/');
    flag2=0;
    mode=1;
    } else
    { if(i==1)
    { if(PINC.4==0)
    { while(PINC.4==0)
    lcd_putchar('4');
    setNum(4);
    } if(PINC.5==0)
    { while(PINC.5==0)
    lcd_putchar('5');
    setNum(5);
    } if(PINC.6==0)
    { while(PINC.6==0)
    lcd_putchar('6');
    setNum(6);
    } if(PINC.7==0)
    { while(PINC.7==0)
    { flag=1;
    flag2=0;
    lcd_putchar('*');
    mode=2;
    } else
    { if(i==2)
    { if(PINC.4==0)
    { while(PINC.4==0)
    lcd_putchar('1');
    setNum(1);
    } if(PINC.5==0)
    { while(PINC.5==0)
    lcd_putchar('2');
    setNum(2);
    } if(PINC.6==0)
    { while(PINC.6==0)
    lcd_putchar('3');
    setNum(3);
    } if(PINC.7==0)
    { while(PINC.7==0)
    { flag=1;
    flag2=0;
    lcd_putchar('-');
    mode=3;
    } else
    { if(i==3)
    { if(PINC.4==0)
    { while(PINC.4==0)
    num1=0;
    num2=0;
    flag=0;
    flag2=0;
    lcd_clear();
    } if(PINC.5==0)
    { while(PINC.5==0)
    lcd_putchar('0');
    setNum(0);
    } if(PINC.6==0)
    { while(PINC.6==0)
    switch(mode)
    { case 1:
    { dev();
    break;
    } case 2:
    { mul();
    break;
    } case 3:
    { sub();
    break;
    } case 4:
    { sum();
    break;
    } if(PINC.7==0)
    { while(PINC.7==0)
    { flag=1;
    flag2=0;
    lcd_putchar('+');
    mode=4;
    void setNum(int n)
    if(flag==1)
    { num2=(num2)*10;
    num2+=n;
    } else if(flag==0)
    { num1=(num1)*10;
    num1+=n;
    void sum()
    num1=answer;
    num2=0;
    lcd_clear();
    lcd_puts(buffer);
    flag2=1;
    void mul()
    num2=0;
    num1=answer;
    lcd_clear();
    lcd_puts(buffer);
    flag2=1;
    void dev()
    num2=0;
    lcd_clear();
    num1=answer;
    lcd_puts(buffer);
    flag2=1;
    void sub()
    num1=answer;
    num2=0;
    lcd_clear();
    lcd_puts(buffer);
    flag2=1;
  • and does the code - as posted - look good to you?
  • I'm a student of Hardware and want to design a calculator with Keypad and Board MCB2300.
    In Proteus, work this code without problem.
    Can you help me?
  • That doesn't make sense!
    You said at the start of this thread that the code wouldn't even build - so it can't possibly have worked!
  • regardless there are two possibilities
    1) you have downloaded some code that does not work and cry Hilfe - no help for that
    2) you have made the beginner mistake of writing the whole shebang instead of gradually writing the code and continuously testing (catch a key, verify - write constant message - verify - ...)
